compile FreeCAD 0.17 with occt 7.1.0 and netgen, script for Xenial and Jessie
jeno
Re: compile FreeCAD 0.17 with occt 7.0.0 and netgen, script for Xenial and Jessie
Post by jeno »
Jee-Bee wrote:
Ubuntu@UserName:~$ sh Downloads/Xenial--FreeCAD_all.sh
Just a shot in the dark. Could you replace sh with bash. Afaik under Ubuntu sh points to dash and not to bash. Maybe that solves the issue
cheers
jeno
Jee-Bee
Post by Jee-Bee »
jeno wrote:Just a shot in the dark. Could you replace sh with bash. Afaik under Ubuntu sh points to dash and not to bash. Maybe that solves the issue
cheers
jeno
Don know what the difference is but building is now at 45% a lot better...
bernd
Post by bernd »
@Jee-Bee
did the build finishes?
Jee-Bee
Post by Jee-Bee »
bernd wrote:@Jee-Bee
Sorry forgot to tell... freecad compiles and is mostly working... :D
jeepsterjc
Post by jeepsterjc »
Thank you for the script. I'm now able to try out 0.17 on Jessie!
bernd
Post by bernd »
jeepsterjc wrote:Thank you for the script. I'm now able to try out 0.17 on Jessie!
cool, I'm glad it worked for you!
kkremitzki
Post by kkremitzki »
What happens when you do this?
wget https://gist.githubusercontent.com/berndhahnebach/38d5bfe73134928c0a1ad001a94df05f/raw/b6efa1423a38ba16ba0d7ae0757e4c4d236b5dfc/Xenial--FreeCAD_all.sh
chmod +x ./Xenial--FreeCAD_all.sh
sodelo
Post by sodelo »
I tried the script on a Linux Mint 18 system and got the following error message:
[ 13%] Built target FreeCADApp
[ 13%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/Application.cpp.o
/home/dominique/Documents/build_FreeCAD/freecad/FreeCAD/src/Gui/Application.cpp:41:22: fatal error: QGLFormat: Aucun fichier ou dossier de ce type
compilation terminated.
src/Gui/CMakeFiles/FreeCADGui.dir/build.make:1135 : la recette pour la cible « src/Gui/CMakeFiles/FreeCADGui.dir/Application.cpp.o » a échouée
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/Application.cpp.o] Erreur 1
CMakeFiles/Makefile2:4903 : la recette pour la cible « src/Gui/CMakeFiles/FreeCADGui.dir/all » a échouée
make[1]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/all] Erreur 2
Makefile:127 : la recette pour la cible « all » a échouée
make: *** [all] Erreur 2 Any idea?
Thanks
HoWil
Post by HoWil »
Is it possible to pin this topic? I think bernd's scripts are used a lot.
I myself always have to search for it :lol: why I would appreciate pinning it to the beginning of page 1.
BR,
HoWil
NormandC
Post by NormandC »
Hi!
OCC 7.1.0 was published November 25th 2016. Is there a reason why your script uses 7.0.0 rather than the latest release?
OCC 7.1.0 brings fixes to the hidden line removal algo that could prove very useful to TechDraw (and maybe Draft Shape2DView) and fix some long standing bugs in FreeCAD.
I'll try to test on Ubuntu 14.04...
