Have any of you successfully compiled libMED on windows? I'm running into some interesting problems, so I thought I would check to see if it worked for anyone before I spend a lot of time troubleshooting. In particular, I'm getting unresolved symbol errors, for example H5T_C_S1_g (hdf5.lib is in the link list)
Thanks,
Peter
libMED on windows
Re: libMED on windows
I had to create a cMake variable and set it to point at the static hdf5.libpeterl94 wrote:Have any of you successfully compiled libMED on windows? I'm running into some interesting problems, so I thought I would check to see if it worked for anyone before I spend a lot of time troubleshooting. In particular, I'm getting unresolved symbol errors, for example H5T_C_S1_g (hdf5.lib is in the link list)
see here: viewtopic.php?f=27&t=15756&start=30#p126231
"fight the good fight"
Thank you! I knew you guys must have had the same issue, but I missed that thread. Anyway, I've found the root cause of the problem. You have to define H5_BUILT_AS_DYNAMIC_LIB, otherwise the macro H5_DLLVAR is not set to the needed __declspec(dllimport).
Thanks for the update. If I go back and do it this way, the bundled builds will me smaller?peterl94 wrote:Anyway, I've found the root cause of the problem. You have to define H5_BUILT_AS_DYNAMIC_LIB, otherwise the macro H5_DLLVAR is not set to the needed __declspec(dllimport).
I suppose you would save some duplication, but if the static lib works fine, I wouldn't bother.
