I have successful out-of-source build and i want to use checkinstall on it. Checkinstall (1.6.2) fails with
[ 0%] Built target Driver
[ 1%] Built target SMDS
[ 1%] Built target SMESHDS
[ 1%] Built target DriverUNV
[ 1%] Built target DriverDAT
[ 2%] Built target DriverSTL
[ 4%] Built target SMESH
[ 4%] Built target MEFISTO2
[ 6%] Built target StdMeshers
[ 10%] Built target FreeCADBase
[ 12%] Built target FreeCADApp
[ 27%] Built target FreeCADGui
[ 27%] Built target FreeCADMain
[ 28%] Built target FreeCADGuiPy
[ 28%] Built target FreeCADMainCmd
[ 28%] Built target FreeCADMainPy
[ 28%] Built target Points
[ 29%] Built target PointsGui
[ 29%] Built target Complete
[ 29%] Built target CompleteGui
[ 29%] Built target Test
[ 29%] Built target QtUnitGui
[ 29%] Built target Image
[ 30%] Built target ImageGui
[ 34%] Built target Mesh
[ 36%] Built target MeshGui
[ 43%] Built target Part
[ 47%] Built target PartGui
[ 47%] Built target Material
[ 47%] Built target MaterialLib
[ 47%] Built target WizardShaft
[ 49%] Built target PartDesign
[ 50%] Built target Sketcher
[ 52%] Built target SketcherGui
[ 55%] Built target PartDesignGui
[ 56%] Built target Raytracing
[ 56%] Built target RaytracingGui
[ 57%] Built target Spreadsheet
[ 58%] Built target Drawing
[ 59%] Built target DrawingGui
[ 62%] Built target Robot
[ 64%] Built target RobotGui
[ 65%] Built target ReverseEngineering
[ 65%] Built target ReverseEngineeringGui
[ 65%] Built target MeshPart
[ 66%] Built target MeshPartGui
[ 67%] Built target Draft
[ 67%] Built target DraftUtils
[ 67%] Built target Web
[ 68%] Built target WebGui
[ 68%] Built target Start
[ 69%] Built target StartGui
[ 70%] Built target Idf
[ 70%] Built target Import
[ 71%] Built target ImportPy
[ 71%] Built target ImportGui
[ 71%] Built target Inspection
[ 72%] Built target InspectionGui
[ 73%] Built target Arch
[ 78%] Built target Fem
[ 83%] Built target FemGui
[ 85%] Built target Ship
[ 85%] Built target OpenSCAD
[ 86%] Built target Plot
[ 87%] Built target SpreadsheetGui
[ 89%] Built target PathScripts
[ 90%] Built target Path
[ 91%] Built target area
[ 92%] Built target PathGui
[ 92%] Built target Show
[ 92%] Built target Measure
[ 95%] Built target TechDraw
[ 98%] Built target TechDrawGui
[100%] Built target Stylesheets_data
[100%] Built target Example_data
Install the project...
-- Install configuration: "Release"
-- Installing: /usr/local/doc/freecad.qhc
-- Installing: /usr/local/doc/freecad.qch
-- Installing: /usr/local/lib/libSMDS.so
-- Set runtime path of "/usr/local/lib/libSMDS.so" to ""
-- Installing: /usr/local/lib/libDriver.so
-- Installing: /usr/local/lib/libDriverSTL.so
-- Set runtime path of "/usr/local/lib/libDriverSTL.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/libDriverDAT.so
-- Set runtime path of "/usr/local/lib/libDriverDAT.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/libDriverUNV.so
-- Set runtime path of "/usr/local/lib/libDriverUNV.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/libSMESHDS.so
-- Set runtime path of "/usr/local/lib/libSMESHDS.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/libSMESH.so
-- Set runtime path of "/usr/local/lib/libSMESH.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/libMEFISTO2.so
-- Installing: /usr/local/lib/libStdMeshers.so
-- Set runtime path of "/usr/local/lib/libStdMeshers.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/libFreeCADBase.so
-- Installing: /usr/local/lib/libFreeCADApp.so
-- Set runtime path of "/usr/local/lib/libFreeCADApp.so" to "/usr/local/lib"
-- Installing: /usr/local/bin/FreeCAD
-- Set runtime path of "/usr/local/bin/FreeCAD" to "/usr/local/lib"
-- Installing: /usr/local/bin/FreeCADCmd
-- Set runtime path of "/usr/local/bin/FreeCADCmd" to "/usr/local/lib"
-- Installing: /usr/local/lib/FreeCAD.so
-- Set runtime path of "/usr/local/lib/FreeCAD.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/FreeCADGui.so
-- Set runtime path of "/usr/local/lib/FreeCADGui.so" to "/usr/local/lib"
-- Installing: /usr/local/Mod/Points/Init.py
-- Installing: /usr/local/Mod/Points/InitGui.py
-- Installing: /usr/local/lib/Points.so
-- Set runtime path of "/usr/local/lib/Points.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/PointsGui.so
-- Set runtime path of "/usr/local/lib/PointsGui.so" to "/usr/local/lib"
-- Installing: /usr/local/data/Mod/Points/Resources/icons/PointsWorkbench.svg
-- Installing: /usr/local/Mod/Complete/Init.py
-- Installing: /usr/local/Mod/Complete/InitGui.py
-- Installing: /usr/local/lib/Complete.so
-- Set runtime path of "/usr/local/lib/Complete.so" to "/usr/local/lib"
-- Installing: /usr/local/lib/CompleteGui.so
-- Set runtime path of "/usr/local/lib/CompleteGui.so" to "/usr/local/lib"
-- Installing: /usr/local/data/Mod/Complete/Resources/icons/CompleteWorkbench.svg
-- Installing: /usr/local/Mod/Test/Init.py
-- Installing: /usr/local/Mod/Test/BaseTests.py
CMake Error at src/Mod/Test/cmake_install.cmake:36 (file):
file INSTALL cannot find
"/usr/local/src/freecad-src/src/Mod/Test/Document.py".
src/Mod/cmake_install.cmake:39 (include)
src/cmake_install.cmake:49 (include)
cmake_install.cmake:37 (include)
1. The file mentioned in the end exists really
2. Source resides at /usr/local/src/freecad-git, build path - /usr/local/src/freecad-0.17git
3. Initial cmake command:
cmake -DFREECAD_USE_EXTERNAL_PIVY=1 -DCMAKE_BUILD_TYPE=Release -DFREECAD_BUILD_ASSEMBLY:BOOL=ON -DCMAKE_CXX_COMPILER=/usr/bin/mpic++ /usr/local/src/freecad-src/
Please bump me into right direction.
