Thank you so much, @sgrogan. Installing animation workbench made it run.Installing the animation wb seems to fix it.
Installing GDAL for the Geodata Workbench
Re: Installing GDAL for the Geodata Workbench
FYI I've opened a ticket on FreeCAD-addons to create a pre-requisite checker that would simplify this process of checking what pre-reqs each addon would need but it is no small task.
Linking to Thread tracking FreeCAD & QGIS integration
Have you had any success fiddling with gdal in FC?rotgut wrote:ping
Hello
Firstly, thanks to the developper of this workbench, it is fantastic.
I am trying to install GDAL, that's why I am continuing this thread.
I have installed the GeoData Workbench from Github. To install GDAL, I was "inspired" by this document located at http://geotribu.net/node/636.
It's in French but there are lots of screenshots. Basically I downloaded and installed "gdal-202-1800-x64-core.msi" and "GDAL-2.2.2.win-amd64-py2.7.msi" from http://www.gisinternals.com/stable.php.
The Workbench works I would say at 98% but I would like to import an ASTER file and here is my problem.
I have tested the following modules in the FreeCAD Python console and they all work well.
However, this one returns an error:
When I open my aster file, I get a similar error message:
Can someone help?
Thanks
OS: Windows 7
Version: 0.17.11827 (Git)
Hash: ca4488f4387f761df47322038585b23cb5a1bd73
Python version: 2.7.8
OCC version: 7.1.0
Locale: French/Switzerland (fr_CH)
from osgeo import gdal
from osgeo import ogr
from osgeo import osr
from osgeo import gdalconst
from osgeo import gdal_array
RuntimeError: module compiled against API version 0xb but this version of numpy is 0x9
File "D:\prive\applications\FreeCAD 0.17_11827\bin\lib\site-packages\osgeo\gdal_array.py", line 26, in <module>
_gdal_array = swig_import_helper()
File "D:\prive\applications\FreeCAD 0.17_11827\bin\lib\site-packages\osgeo\gdal_array.py", line 22, in swig_import_helper
_mod = imp.load_module('_gdal_array', fp, pathname, description)
ImportError: numpy.core.multiarray failed to import
File "D:\prive\applications\FreeCAD 0.17_11827\Mod\geodata\geodat\import_aster.py", line 182, in runbl
import_heights(float(b),float(l),float(s))
File "D:\prive\applications\FreeCAD 0.17_11827\Mod\geodata\geodat\import_aster.py", line 218, in import_heights
pcl=import_ast(b,l)
File "D:\prive\applications\FreeCAD 0.17_11827\Mod\geodata\geodat\import_aster.py", line 85, in import_ast
data = band.ReadAsArray(0, 0, cols, rows)
File "D:\prive\applications\FreeCAD 0.17_11827\bin\lib\site-packages\osgeo\gdal.py", line 2344, in ReadAsArray
import gdalnumeric
File "D:\prive\applications\FreeCAD 0.17_11827\bin\lib\site-packages\osgeo\gdalnumeric.py", line 1, in <module>
from osgeo.gdal_array import *
Can someone help?
Thanks
OS: Windows 7
OCC version: 7.1.0
- microelly2
There are some problems with the common version of numpy,
for windows there is a way, see the links from this
https://forum.freecadweb.org/viewtopic. ... 50#p196630
Thanks for your quick answer.
I read this thread (https://forum.freecadweb.org/viewtopic.php?f=4&t=20674) and I think I will be stuck with FreeCAD 0.17.
I have the 0.16 64 bits and with that one, it will not work either.
Solution is to move to 0.16 32 bits or to another OS...
Walter
Walter
Don't know if it is possible... what i was thinking add a terminal inside FreeCAD/ make terminal work within the FreeCAD location... than it is easy to do a pip install
- microelly2
I'm at home for the next days, so I will spend the time to make a tutorial to install some powerful moduls (scipy,cv2,networkx,gdal, ...) around freecad to get the jobs running.
For windows, Ubuntu etc/ osx or more than one?
