As a new user, I hope to address the issue below to the right group.
After updating of my system the new deb package of FreeCAD
OS: Debian GNU/Linux 9.0 (stretch)
Version: 0.16, Libs: 0.16R
Build type: None
Python version: 2.7.13
OCC version: 6.8.0.oce-0.17
was installed (Info obtained from the menu About FreeCAD and the console). Starting FreeCAD with
$ freecad &
generates plenty of errors:
** (freecad:8492): WARNING **: invalid source position for horizontal gradient
I don't know whether this is in relation with the later error when using the Draft module and trying to create a circle or an ellipse:
Pick center point:
Pick radius:
Coin warning in SbMatrix::inverse(): Matrix is singular.
Coin warning in SbDPLine::setValue(): The two points defining the line is equal => line is invalid.
Coin warning in SbLine::setValue(): The two points defining the line is equal => line is invalid.
Trying to upgrade the circle or the ellipse is not possible, Error on the console:
Unable to upgrade these objects.
Might this be a bug of this Debian package?
My system:
Linux <myhostname> 4.8.0-2-amd64 #1 SMP Debian 4.8.11-1 (2016-12-02) x86_64 GNU/Linux
Thanks in advance for any hint!
Error "Invalid source position for horizontal gradient" after starting
Re: Error "Invalid source position for horizontal gradient" after starting
Welcome to the forum.
It's a self-contained package that can run on most recent Linux distros. All you need to do is to make it executable then launch it.
It's possible. Could you try out the AppImage build available here? Downloadjuaco13 wrote:Might this be a bug of this Debian package?
Thanks a lot for this hint. I tried with the AppImage build, it works fine. However, the warning messageNormandC wrote:Hello,It's possible. Could you try out the AppImage build available here? Downloadjuaco13 wrote:Might this be a bug of this Debian package?
** (freecad:13169): WARNING **: invalid source position for horizontal gradient
Trying the same with my currently installed Debian package: it also works! While for a circle (or ellipse) I had to set manually "Make Face" to "True", for rectangle or polygon this is not needed at all, even if that option is set to "False" by default. Also interesting is the vector in which the structure grows when generating. Rectangles/polygons on the XY plane grow in positive, circles/ellipses in the negative Z direction. This does not matters much, however one would expect a similar behavior.
Thanks a lot for your help!
