I'm on a fresh install of Debian Jessie, using a slightly modified version of this shell script that worked fine a few weeks ago (though that was not on a fresh install).
After an apparently succesful compile, it gets to cmaking freecad and then spits out this:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
NGLIB_INCLUDE_DIR
used as include directory in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
NGLIB_LIBNGLIB
linked by target "Driver" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "DriverDAT" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "DriverSTL" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "DriverUNV" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "MEFISTO2" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "NETGENPlugin" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "SMDS" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "SMESH" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "SMESHDS" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
linked by target "StdMeshers" in directory /home/alex/Documents/code/build_FreeCAD/freecad/FreeCAD/src/3rdParty/salomesmesh
-- Configuring incomplete, errors occurred!
