I'm trying to get git version running. It compiles fine on VC2013 using FreeCADLibs_11.5.2_x64_VC12 libpack.
When trying to use PartDesign feature like Pad or Revolve it crushes when I cancel the Parameter dialog.
I thought it's a bug but release version works fine. I've compiled the same git commit as release's but it still crushes.
Is it possible that libpack version is not right? I used to compile and run 0.17 Freecad many times before and never had any problem.
Thanks.
Compiled version shows strange bug compared to release version
C++ beginner, willing to help FC with coding. Using FC for converting/decomposing STEP models into iges.
- DeepSOIC
Re: Compiled version shows strange bug compared to release version
Hi!
Just in case you haven't yet, try doing a clean build (or rebuild from scratch).
Magically it started to work, even though I built and rebuilt it several times, including fresh re-build with deleted cmake cache.. I've updated to most recent commit, maybe that helped, I don't know. Anyway, I'm happy Thanks!
Just a thought, do you have multiple versions of OCC or some other lib, on your system and if so, could cake be finding the wrong one?poserge wrote:Magically it started to work, even though I built and rebuilt it several times, including fresh re-build with deleted cmake cache.. I've updated to most recent commit, maybe that helped, I don't know. Anyway, I'm happy Thanks!
