Problems compiling with PIvy
Hi I'm trying to install FreeCAD 0:16 on my Slackware chart using the SlackBuild, downloaded from https://slackbuilds.org/repository/14.2 ... ch=freecad, I compiled and installed the dependencies:
shiboken 1.2.2
Xerces-c 3.1.4
pyside (qt4.8+1.2.2)
pyside-tools 0.2.15
OpenCASCADE 6.9.1
matplotlib 1.5.2
reached Pivy-hg_20101207.tar.bz2, I have problems, compiling stops, giving the following error message
building 'gui._soqt' extension
creating build/temp.linux-x86_64-2.7
creating build/temp.linux-x86_64-2.7/pivy
creating build/temp.linux-x86_64-2.7/pivy/gui
gcc -pthread -fno-strict-aliasing -g -O2 -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c pivy/gui/soqt_wrap.cpp -o build/temp.linux-x86_64-2.7/pivy/gui/soqt_wrap.o -Iinterfaces -I/usr/include/Inventor/annex -D_REENTRANT -DQT_SHARED -I/usr/lib64/qt/include/QtOpenGL -I/usr/lib64/qt/include/QtGui -I/usr/lib64/qt/include/QtCore
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
pivy/gui/soqt_wrap.cpp: In function 'void initialize_pyqt_module_import_name()':
pivy/gui/soqt_wrap.cpp:3806:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PYQT_MODULE_IMPORT_NAME = "qt";
pivy/gui/soqt_wrap.cpp:3810:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PYQT_MODULE_IMPORT_NAME = "PyQt4.Qt";
pivy/gui/soqt_wrap.cpp: In function 'PyObject* _wrap_delete_SoQtObject(PyObject*, PyObject*)':
pivy/gui/soqt_wrap.cpp:18579:10: warning: deleting object of abstract class type 'SoQtObject' which has non-virtual destructor will cause undefined behaviour [-Wdelete-non-virtual-dtor]
delete arg1;
g++ -pthread -shared build/temp.linux-x86_64-2.7/pivy/gui/soqt_wrap.o -L/usr/lib64 -lpython2.7 -o build/lib/pivy/gui/_soqt.so -L/usr/lib64 -lSoQt -lXmu -L/usr/lib64/qt/lib -lQtOpenGL -lQtGui -lQtCore -lXi -lCoin -lGL -lXext -lSM -lICE -lX11 -ldl -lpthread
building '_coin' extension
gcc -pthread -fno-strict-aliasing -g -O2 -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c pivy/coin_wrap.cpp -o build/temp.linux-x86_64-2.7/pivy/coin_wrap.o -Iinterfaces -I/usr/include/Inventor/annex -D_REENTRANT
gcc: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
error: command 'gcc' failed with exit status 4
my system configuration:
gcc 5.3.0
python 2.7
kernel 4.4.9
KDE 04/14/18
I searched on the forum and I found these two solutions
https://forum.freecadweb.org/viewtopic.php?t=8097
http://forums.fedoraforum.org/archive/i ... 74836.html
but they do not work.
Thank you for any help you can give me.
