Failed to initialise Shiboken.BaseWrapper type
axk
Post by axk »
I just did a git pull and a clean build. Compilation was clean and uneventful, however I get this error when starting up:
FreeCAD 0.17, Libs: 0.17R10411 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2017
Fatal Python error: [libshiboken] Failed to initialise Shiboken.BaseWrapper type.
Aborted
Any advice on where to begin debugging this? Is my local shiboken at fault?
I am running the stock libs installed that are available with arch linux:
local/python-shiboken 1.2.4-3
    Support library for Python bindings
local/python2-shiboken 1.2.4-3
    Support library for Python2 bindings
local/shiboken 1.2.4-3
    CPython bindings generator for C++ libraries
Am I on an old version of some python collateral?
thanks in advance
looo
Re: Failed to initialise Shiboken.BaseWrapper type
Post by looo »
you have installed shiboken for python2 and python3?
With this commit cmake takes the default config for shiboken and pyside. And maybe in your case this is the python3 version...
You can try setting the variables manually:
cmake
-DPYTHON_SUFFIX=..., #look for this file <ShibokenConfigPYTHON_SUFFIX.cmake>
-DPYTHON_BASENAME=... #look for this file <PySideConfigPYTHON_BASENAME.cmake>
ps.: maybe you can try this branch. There the behavior is revered for python2.
triplus
Post by triplus »
Hopefully commit by @looo will sort it out. But if it won't am i correct in guessing you are trying to build against Qt 5? If yes this is what i had to use in the past:
https://forum.freecadweb.org/viewtopic. ... 20#p121791
axk
Post by axk »
looo wrote:you have installed shiboken for python2 and python3?
cmake
Thanks for the suggestion. I will try that. This is what I have currently set:
CMakeLists.txt: SET(PYTHON_SUFFIX -python2.7) # for shiboken
CMakeLists.txt: SET(PYTHON_BASENAME -python2.7) # for PySide
treslah
Post by treslah »
Same problem here on Gentoo:
shiboken pyside all compiled with py2_7 and py3_5 on the system
Please:
Can please someone advise on exactly howto fix this, or even better: patch it in the source code ?!?
I doubt it'll fix itself as suggested ;-)
Founder
Post by wmayer »
Post the content of the file ShibokenConfig.cmake
For me it is:
if (NOT PYTHON_SUFFIX)
    message(STATUS "Using default python: -python2.7")
endif()
include(/usr/lib/x86_64-linux-gnu/cmake/Shiboken-1.2.1/ShibokenConfig${PYTHON_SUFFIX}.cmake)
This means it sets PYTHON_SUFFIX to -python2.7. So, it's consistent with the Python version FreeCAD is built with.
J.Martinsson
Post by J.Martinsson »
I have the same problem with Arch Linux. A build for 2-3 weeks ago was fine but not when I did a new build two days ago.
My ShibokenConfig.cmake (/usr/lib/cmake/Shiboken-1.2.4/ShibokenConfig.cmake)
    message(STATUS "Using default python: .cpython-36m-x86_64-linux-gnu")
    SET(PYTHON_SUFFIX .cpython-36m-x86_64-linux-gnu)
endif()
include(/usr/lib/cmake/Shiboken-1.2.4/ShibokenConfig${PYTHON_SUFFIX}.cmake)
On my system it locks that it is only freecad (git checkout version of it) which require shiboken (by python2-pyside) so I guess i can change ShibokenConfig.cmake. But is there a better way that not affect other application if the were effected by shiboken?
looo
Post by looo »
Which option are you using to run cmake? I wonder because, if python3 is the default version on your system, cmake should use this version by default... and then the build should fail anyway.
Please test if this branch work for you: https://github.com/looooo/FreeCAD/tree/python3-cmake
treslah
Post by treslah »
@wmayer
Shiboken 1.2.2
message(STATUS "Using default python: -python3.4")
SET(PYTHON_SUFFIX -python3.4)
endif()
include(/usr/lib64/cmake/Shiboken-1.2.2/ShibokenConfig${PYTHON_SUFFIX}.cmake)
I'll set PYTHON_SUFFIX manually an do a new build. I'll report back ....
@looo
Py34 is the default but the emerge script specifies to use py27 for the build. So the build process works. I'll have a look at the log file and report back ...
Founder
Post by wmayer »
In this case you also have to set PYTHON_SUFFIX and PYTHON_BASE in the script.
This effectively reverts the recent change when Python 2.x is used. So, when a PR is made this can be merged and the build should work normally again.
