ana(conda) windows packaging
sgrogan
Re: ana(conda) windows packaging
Postby sgrogan » Thu Apr 20, 2017 10:51 pm
Thanks everyone who worked on the OCCT7.1 stuff for win!
looo wrote:Code: Select all
conda create -n <name> freecad occt=7.0.0
I get
# All requested packages already installed.
# packages in environment at C:\Users\Chris\Miniconda3:
conda                     4.3.16                   py35_0    conda-canary
(C:\Users\Chris\Miniconda3) C:\Users\Chris>conda create -n fcocc7 freecad occt=7
.0.0
Fetching package metadata .............
PackageNotFoundError: Package missing in current win-64 channels:
  - freecad
Close matches found; did you mean one of these?
    freecad: freetds
looo
Postby looo » Fri Apr 21, 2017 7:40 am
is the freecad-channel in the config?
conda config --show-sources
ps.: Currently I can not build with windows. I will upload a new build with occt7.1.0 next week.
sgrogan
Postby sgrogan » Fri Apr 21, 2017 10:46 pm
looo wrote:is the freecad-channel in the config?
OS: Windows 7
Version: 0.17.10700 (Git)
Branch: py3-25
Hash: 79ecc1689ee4888341425dda3312acdf99b85742
Python version: 3.5.3
OCC version: 7.0.0
looo
Postby looo » Mon Apr 24, 2017 5:41 pm
FreeCAD occt7.1.0 version is uploaded.
sgrogan
Postby sgrogan » Mon Apr 24, 2017 10:30 pm
looo wrote:FreeCAD occt7.1.0 version is uploaded.
Thanks :D
OS: Windows 7
Version: 0.17.11022 (Git)
Branch: py3-26
Hash: ba81bf9e5b348000f49577f4e67c432c5171c165
OCC version: 7.1.0
Installs and runs, but plenty to work on.
1) obvious python stuff (mixed spaces/tabs, missing () in prints), stuff I can fix
2) probably python stuff (i.e.
  File "C:\Users\Chris\Miniconda3\envs\fcocc71\Library\Mod\Arch\ArchProfile.py", line 65, in readPresets
    for row in beamreader:
_csv.Error: iterator should return strings, not bytes (did you open the file in text mode?)
), more difficult for me to fix.
3) packaging (missing .dll's)
How best can I contribute. For ex. 1) make a pull request against master or your py3 fork? For 3) should I concentrate on learning to do the conda builds, or concentrate on reporting the problems? We'll probably need Peter's help either way.
Like everyone else, time is limited, so I'd like to use it most efficiently for the greater goal.
looo
Postby looo » Tue Apr 25, 2017 5:52 am
Thanks for testing!
I am quite unsure how to proceed. As you may know I have written a proposal for gsoc (py3 support). So there I have proposed to work on the python3 branch. How I proceed with python3 is up to the decission of gsoc...
This list https://github.com/looooo/FreeCAD/issues/8 gives an overview of the modules without diff. so doing a PR directly on master is the best idea. (for arch). The py3branch gets rebased quite frequently, so the pr should land there soon after it is accepted in master.
I will try to create a seperate python3 repo to have a place for python3 issues. I think it doesn't make much sense to create bug-reports with mantis at the moment?
looo
Postby looo » Tue Apr 25, 2017 8:23 am
It seems there is no way to have a second fork with github. So maybe the best idea is to create issues in my FreeCAD fork on github and add a "python3" label.
CADennis
Postby CADennis » Tue Apr 25, 2017 4:55 pm
looo wrote:Thanks for testing!
I am quite unsure how to proceed. As you may know I have written a proposal for gsoc (py3 support). So there I have proposed to work on the python3 branch. How I proceed with python3 is up to the decission of gsoc... [...]
:arrow: looo, please have a look there, how we could get Py3+Py2 stabelized, on both Conda and native OS installers: https://forum.freecadweb.org/viewtopic. ... 19#p171319
