OSX background color in 3D view is always black
Postby chrisb » Sun Apr 02, 2017 9:03 am
I cannot tell exactly because I deleted the old version to try with the current 0.17 but it happened just a couple of days ago:.
When I load an existing or create a new model the background of 3D view turns completely black. It is extremely difficult to see black lines like in wireframe display mode although they are not really black but of darkest grey.
When I open the submenu for the draw styles the color is displayed normal for a couple of seconds and then turning black again. If I try to screenshot the normal version the color in the screenshot is still black.
OS: Mac OS X
Version: 0.17.10672 (Git)
Branch: (HEAD detached at 1bde451)
Hash: 1bde45172ea49a618299dd9003784d5c69fc3ff9
Python version: 2.7.13
Qt version: 5.6.2
OCC version: 7.1.0
NormandC
Re: OSX background color in 3D view is always black
Postby NormandC » Sun Apr 02, 2017 9:07 am
Just a shot in the dark, have you tried deleting/renaming your system.cfg and user.cfg files so new ones are created?
Otherwise, I wonder if it's related to the switch to Qt5? I don't remember when the switch occurred for the OSX builds.
Postby chrisb » Sun Apr 02, 2017 9:15 am
NormandC wrote:Just a shot in the dark, have you tried deleting/renaming your system.cfg and user.cfg files so new ones are created?
Thanks, it was the shot in the dark (or better: in the black :lol: ). I deleted the config files and everything was like new!
NormandC
Re: [solved] OSX background color in 3D view is always black
Postby NormandC » Tue Apr 04, 2017 1:19 am
Cool!
The "delete system.cfg/user.cfg" combo is like FreeCAD's own version of "format c:". :P
Postby chrisb » Wed Apr 05, 2017 6:36 am
It was the setting of the background color: If it is set to solid instead of color gradient it is ok.
Site Admin
Postby wmayer » Wed Apr 05, 2017 7:52 am
chrisb wrote:It was the setting of the background color: If it is set to solid instead of color gradient it is ok.
So, when you set the color gradient, create a new document and add a new object then does the background also become black or does this only happen when loading a project file?
Once the background is black what happens when doing box zoom or box selection?
Do you have a chance to test this with the Qt4 build? If so does it happen there too?
Postby chrisb » Wed Apr 05, 2017 10:56 pm
I am sorry, I mixed things up: With color gradient it is ok, with bgcolor solid ("simple color" in the preferences) I get the black background.
If you think it might be sensible to check with the newest commit and QT5 as well, please let me know.
In detail:
OS: Mac OS X
Qt version: 5.6.2
OCC version: 7.1.0
bgcolor: gradient
- create new document, new object. OK
- load existing document: OK
bgcolor: simple color
- create new document: background stays grey until I change in combo between "Task" and "Model", no matter which direction. Then it stays black whatever I do.
- load existing document: same behaviour, the background becomes and stays black as soon as I change the combo view.
OS: Mac OS X
Version: 0.17.10692 (Git)
Branch: (detached from 8337a79)
Hash: 8337a7909fb9395a8a931d466b0cee13ea52e5c6
OCC version: 7.1.0
All use cases from above are OK.
(I will remove the "solved" from the first post.)
Site Admin
Postby wmayer » Thu Apr 06, 2017 7:01 am
OK, then as a workaround you can use the color gradient and set both colors the same. But again are you able to build the latest FreeCAD revision against Qt4 to see if the issue might be related to the Qt5 port?
Also does the background go (tmp.) back to normal when you do box zoom/selection? Internally the viewer tmp. changes to a different render mode.
Postby chrisb » Thu Apr 06, 2017 9:04 am
Installed the current version for QT5. The QT4 is built against the latest FreeCAD version (at least it was yesterday), they are only 2 commits apart. The version described below shows the same behaviour as the QT5 version from above.
Box selection behaviour: While dragging the box I can see the color in the box. It turns to black immediately after the zoom.
OS: Mac OS X
Version: 0.17.10694 (Git)
Branch: (detached from aa086c1)
Hash: aa086c1dd93a9fcd497e0c9a6525d8338a312013
Qt version: 5.6.2
OCC version: 7.1.0
Site Admin
Postby wmayer » Thu Apr 06, 2017 10:53 am
