problem installing the drawing-dimensioning workbench
Ivan_Ryger
Postby Ivan_Ryger » Mon Apr 17, 2017 10:33 pm
Dear all,
I am a relatively new user of Freecad. Recently I needed to generate drawings with dimensions. For this reason, I downloaded a drawing dimensioning workbench from Github https://github.com/hamish2014/FreeCAD_drawing_dimensioning .
However, I am not able to make it working.
According to this article https://www.freecadweb.org/wiki/Sandbox:Drawing_Dimensioning I tried to make a directory called DrawingDimension in the Freecad/mod subdirectory and copy the respective files there.
When I opened the Freecad environment, I got the following error message:
During initialization the error DLL load failed: The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail. occurred in C:\Program Files (x86)\FreeCAD 0.16\Mod\DrawingDimension\InitGui.py
When I looked into Event log, I saw this:
Activation context generation failed for "C:\Program Files (x86)\FreeCAD 0.16\bin\lib\site-packages\numpy\core\multiarray.pyd". Dependent Assembly Microsoft.VC90.DebugCRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8" could not be found. Please use sxstrace.exe for detailed diagnosis.
It looks like multiarray.pyd file is missing. Now, I do not know, what to do next. I appreciate any help. Thank you.
r-frank
Re: problem installing the drawing-dimensioning workbench
Postby r-frank » Tue Apr 18, 2017 5:42 am
Hello Ivan.
Welcome to FreeCAD and he forum.
If i read you correct it depends on your FreeCAD version and operating system
how this problem needs to be resolved.
Please provide your FreeCAD info like describd here.
Roland
My GrabCAD FreeCAD-Projects
Ivan_Ryger
Postby Ivan_Ryger » Tue Apr 18, 2017 2:47 pm
dear r-frank
this is the information:
OS: Windows 7
Word size of FreeCAD: 32-bit
Version: 0.16.6704 (Git)
Branch: releases/FreeCAD-0-16
Hash: 0c449d7e8f9b2b1fb93e3f8d1865e2f59d7ed253
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
r-frank
Postby r-frank » Tue Apr 18, 2017 2:56 pm
Hello Ivan.
1) please de-install your FreeCAD Version, download 0.16.6706 for Windows 32 bit from Download-page and install (0.16.6704 has several Bugs)
2) with 0.16.6706 there is a buggy Version of NUMPY (needed by drawing dimensioning)
3) replace this Version manually like described here
4) install addon-manager
5) install drawing dimensioning
Now everything should be fine ...
Roland
Ivan_Ryger
Postby Ivan_Ryger » Tue Apr 18, 2017 11:20 pm
dear r-Frank.
Thank you for guidance, i reinstalled Freecad with the abovementioned release and now everything works fine.
Ivan
