checking for boost... configure: error: failed
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by FreeCAD configure 0.7.2008, which was
generated by GNU Autoconf 2.63. Invocation command line was
$ ./configure
## Platform. ##
hostname = biot
uname -m = x86_64
uname -r = 2.6.26-1-amd64
uname -s = Linux
uname -v = #1 SMP Sat Jan 10 17:57:00 UTC 2009
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/games
## Core tests. ##
configure:2196: checking for a BSD-compatible install
configure:2264: result: /usr/bin/install -c
configure:2275: checking whether build environment is sane
configure:2318: result: yes
configure:2343: checking for a thread-safe mkdir -p
configure:2382: result: /bin/mkdir -p
configure:2395: checking for gawk
configure:2411: found /usr/bin/gawk
configure:2422: result: gawk
configure:2433: checking whether make sets $(MAKE)
configure:2455: result: yes
configure:2634: checking how to create a ustar tar archive
configure:2647: tar --version
tar (GNU tar) 1.22
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
configure:2650: $? = 0
configure:2690: tardir=conftest.dir && eval tar --format=ustar -chf - "$tardir" >conftest.tar
configure:2693: $? = 0
configure:2697: tar -xf - <conftest.tar
configure:2700: $? = 0
configure:2713: result: gnutar
configure:2745: checking for C++ header files
configure:2759: checking for style of include used by make
configure:2787: result: GNU
configure:2867: checking for g++
configure:2883: found /usr/bin/g++
configure:2894: result: g++
configure:2921: checking for C++ compiler version
configure:2929: g++ --version >&5
g++ (Debian 4.3.3-8) 4.3.3
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2933: $? = 0
configure:2940: g++ -v >&5
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 4.3.3-8' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --enable-multiarch --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3 --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.3.3 (Debian 4.3.3-8)
configure:2944: $? = 0
configure:2951: g++ -V >&5
g++: '-V' option must have argument
configure:2955: $? = 1
configure:2978: checking for C++ compiler default output file name
configure:3000: g++ conftest.cpp >&5
configure:3004: $? = 0
configure:3042: result: a.out
configure:3061: checking whether the C++ compiler works
configure:3071: ./a.out
configure:3075: $? = 0
configure:3094: result: yes
configure:3101: checking whether we are cross compiling
configure:3103: result: no
configure:3106: checking for suffix of executables
configure:3113: g++ -o conftest conftest.cpp >&5
configure:3117: $? = 0
configure:3143: result:
configure:3149: checking for suffix of object files
configure:3175: g++ -c conftest.cpp >&5
configure:3179: $? = 0
configure:3204: result: o
configure:3208: checking whether we are using the GNU C++ compiler
configure:3237: g++ -c conftest.cpp >&5
configure:3244: $? = 0
configure:3261: result: yes
configure:3270: checking whether g++ accepts -g
configure:3300: g++ -c -g conftest.cpp >&5
configure:3307: $? = 0
configure:3408: result: yes
configure:3433: checking dependency style of g++
configure:3524: result: gcc3
configure:3545: checking how to run the C++ preprocessor
configure:3581: g++ -E conftest.cpp
configure:3588: $? = 0
configure:3619: g++ -E conftest.cpp
conftest.cpp:10:28: error: ac_nonexistent.h: No such file or directory
configure:3626: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "FreeCAD"
| #define PACKAGE_TARNAME "FreeCAD"
| #define PACKAGE_VERSION "0.7.2008"
| #define PACKAGE_STRING "FreeCAD 0.7.2008"
| #define PACKAGE_BUGREPORT "wmayer@users.sourceforge.net"
| #define PACKAGE "FreeCAD"
| #define VERSION "0.7.2008"
| /* end confdefs.h. */
| #include <ac_nonexistent.h>
configure:3659: result: g++ -E
configure:3688: g++ -E conftest.cpp
configure:3695: $? = 0
configure:3726: g++ -E conftest.cpp
configure:3733: $? = 1
| /* confdefs.h. */
configure:3773: checking for grep that handles long lines and -e
configure:3833: result: /bin/grep
configure:3838: checking for egrep
configure:3902: result: /bin/grep -E
configure:3907: checking for ANSI C header files
configure:3937: g++ -c -g -O2 conftest.cpp >&5
configure:3944: $? = 0
configure:4043: g++ -o conftest -g -O2 conftest.cpp >&5
configure:4047: $? = 0
configure:4053: ./conftest
configure:4057: $? = 0
configure:4075: result: yes
configure:4099: checking for sys/types.h
configure:4120: g++ -c -g -O2 conftest.cpp >&5
configure:4127: $? = 0
configure:4144: result: yes
configure:4099: checking for sys/stat.h
configure:4099: checking for stdlib.h
configure:4099: checking for string.h
configure:4099: checking for memory.h
configure:4099: checking for strings.h
configure:4099: checking for inttypes.h
configure:4099: checking for stdint.h
configure:4099: checking for unistd.h
configure:4180: checking istream usability
configure:4197: g++ -c -g -O2 conftest.cpp >&5
configure:4204: $? = 0
configure:4218: result: yes
configure:4222: checking istream presence
configure:4237: g++ -E conftest.cpp
configure:4244: $? = 0
configure:4258: result: yes
configure:4291: checking for istream
configure:4300: result: yes
configure:4180: checking ostream usability
configure:4222: checking ostream presence
configure:4291: checking for ostream
configure:4169: checking for istream
configure:4176: result: yes
configure:4180: checking fstream usability
configure:4222: checking fstream presence
configure:4291: checking for fstream
configure:4180: checking ios usability
configure:4222: checking ios presence
configure:4291: checking for ios
configure:4180: checking iomanip usability
configure:4222: checking iomanip presence
configure:4291: checking for iomanip
configure:4180: checking iostream usability
configure:4222: checking iostream presence
configure:4291: checking for iostream
configure:4334: checking iomanip.h usability
configure:4351: g++ -c -g -O2 conftest.cpp >&5
conftest.cpp:60:21: error: iomanip.h: No such file or directory
configure:4358: $? = 1
| /* confdefs.h. */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_ISTREAM 1
| #define HAVE_OSTREAM 1
| #define HAVE_FSTREAM 1
| #define HAVE_IOS 1
| #define HAVE_IOMANIP 1
| #define HAVE_IOSTREAM 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <iomanip.h>
configure:4372: result: no
configure:4376: checking iomanip.h presence
configure:4391: g++ -E conftest.cpp
conftest.cpp:27:21: error: iomanip.h: No such file or directory
configure:4398: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
configure:4412: result: no
configure:4445: checking for iomanip.h
configure:4454: result: no
configure:4334: checking limits.h usability
configure:4358: $? = 0
configure:4372: result: yes
configure:4376: checking limits.h presence
configure:4398: $? = 0
configure:4412: result: yes
configure:4445: checking for limits.h
configure:4454: result: yes
configure:4334: checking values.h usability
configure:4376: checking values.h presence
configure:4445: checking for values.h
configure:4334: checking float.h usability
configure:4376: checking float.h presence
configure:4445: checking for float.h
configure:4489: checking siginfo.h usability
configure:4506: g++ -c -g -O2 conftest.cpp >&5
conftest.cpp:63:21: error: siginfo.h: No such file or directory
configure:4513: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
| #define HAVE_LIMITS_H 1
| #define HAVE_VALUES_H 1
| #define HAVE_FLOAT_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <siginfo.h>
configure:4527: result: no
configure:4531: checking siginfo.h presence
configure:4546: g++ -E conftest.cpp
conftest.cpp:30:21: error: siginfo.h: No such file or directory
configure:4553: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
configure:4567: result: no
configure:4600: checking for siginfo.h
configure:4609: result: no
configure:4489: checking bits/sigset.h usability
configure:4513: $? = 0
configure:4527: result: yes
configure:4531: checking bits/sigset.h presence
configure:4553: $? = 0
configure:4567: result: yes
configure:4600: checking for bits/sigset.h
configure:4609: result: yes
configure:4489: checking bstring.h usability
conftest.cpp:64:21: error: bstring.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_IOS 1
| #define HAVE_BITS_SIGSET_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <bstring.h>
configure:4531: checking bstring.h presence
conftest.cpp:31:21: error: bstring.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_IOS 1
configure:4600: checking for bstring.h
configure:4478: checking for sys/types.h
configure:4485: result: yes
configure:4489: checking sys/select.h usability
configure:4531: checking sys/select.h presence
configure:4600: checking for sys/select.h
configure:4642: checking sys/filio.h usability
configure:4659: g++ -c -g -O2 conftest.cpp >&5
conftest.cpp:66:23: error: sys/filio.h: No such file or directory
configure:4666: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
| #define HAVE_SYS_SELECT_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <sys/filio.h>
configure:4680: result: no
configure:4684: checking sys/filio.h presence
configure:4699: g++ -E conftest.cpp
conftest.cpp:33:23: error: sys/filio.h: No such file or directory
configure:4706: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
configure:4720: result: no
configure:4753: checking for sys/filio.h
configure:4762: result: no
configure:4642: checking sys/mman.h usability
configure:4666: $? = 0
configure:4680: result: yes
configure:4684: checking sys/mman.h presence
configure:4706: $? = 0
configure:4720: result: yes
configure:4753: checking for sys/mman.h
configure:4762: result: yes
configure:4642: checking libc.h usability
conftest.cpp:67:18: error: libc.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_IOS 1
| #define HAVE_SYS_MMAN_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <libc.h>
configure:4684: checking libc.h presence
conftest.cpp:34:18: error: libc.h: No such file or directory
| /* confdefs.h. */
| #define HAVE_IOS 1
| #include <libc.h>
configure:4753: checking for libc.h
configure:4793: checking sstream usability
configure:4810: g++ -c -g -O2 conftest.cpp >&5
configure:4817: $? = 0
configure:4831: result: yes
configure:4835: checking sstream presence
configure:4850: g++ -E conftest.cpp
configure:4857: $? = 0
configure:4871: result: yes
configure:4904: checking for sstream
configure:4913: result: yes
configure:4933: checking whether the compiler implements namespaces
configure:4966: g++ -c -g -O2 conftest.cpp >&5
configure:4973: $? = 0
configure:4995: result: yes
configure:5005: checking for std iostream
configure:5046: g++ -c -g -O2 conftest.cpp >&5
configure:5053: $? = 0
configure:5075: result: yes
configure:5198: checking for C++ compiler version
configure:5206: g++ --version >&5
configure:5210: $? = 0
configure:5217: g++ -v >&5
Thread model: posix
configure:5221: $? = 0
configure:5228: g++ -V >&5
configure:5232: $? = 1
configure:5235: checking whether we are using the GNU C++ compiler
configure:5288: result: yes
configure:5297: checking whether g++ accepts -g
configure:5435: result: yes
configure:5460: checking dependency style of g++
configure:5551: result: gcc3
configure:5614: checking for gcc
configure:5630: found /usr/bin/gcc
configure:5641: result: gcc
configure:5873: checking for C compiler version
configure:5881: gcc --version >&5
gcc (Debian 4.3.3-8) 4.3.3
configure:5885: $? = 0
configure:5892: gcc -v >&5
Thread model: posix
configure:5896: $? = 0
configure:5903: gcc -V >&5
gcc: '-V' option must have argument
configure:5907: $? = 1
configure:5910: checking whether we are using the GNU C compiler
configure:5939: gcc -c conftest.c >&5
configure:5946: $? = 0
configure:5963: result: yes
configure:5972: checking whether gcc accepts -g
configure:6002: gcc -c -g conftest.c >&5
configure:6009: $? = 0
configure:6110: result: yes
configure:6127: checking for gcc option to accept ISO C89
configure:6201: gcc -c -g -O2 conftest.c >&5
configure:6208: $? = 0
configure:6231: result: none needed
configure:6251: checking dependency style of gcc
configure:6342: result: gcc3
configure:6454: checking build system type
configure:6472: result: x86_64-unknown-linux-gnu
configure:6494: checking host system type
configure:6509: result: x86_64-unknown-linux-gnu
configure:6531: checking for a sed that does not truncate output
configure:6597: result: /bin/sed
configure:6615: checking for fgrep
configure:6679: result: /bin/grep -F
configure:6714: checking for ld used by gcc
configure:6781: result: /usr/bin/ld
configure:6790: checking if the linker (/usr/bin/ld) is GNU ld
configure:6805: result: yes
configure:6817: checking for BSD- or MS-compatible name lister (nm)
configure:6866: result: /usr/bin/nm -B
configure:6984: checking the name lister (/usr/bin/nm -B) interface
configure:6991: g++ -c -g -O2 conftest.cpp >&5
configure:6994: /usr/bin/nm -B "conftest.o"
configure:6997: output
0000000000000000 B some_variable
configure:7004: result: BSD nm
configure:7007: checking whether ln -s works
configure:7011: result: yes
configure:7019: checking the maximum length of command line arguments
configure:7139: result: 1572864
configure:7156: checking whether the shell understands some XSI constructs
configure:7166: result: yes
configure:7170: checking whether the shell understands "+="
configure:7176: result: yes
configure:7211: checking for /usr/bin/ld option to reload object files
configure:7218: result: -r
configure:7287: checking for objdump
configure:7303: found /usr/bin/objdump
configure:7314: result: objdump
configure:7346: checking how to recognize dependent libraries
configure:7542: result: pass_all
configure:7602: checking for ar
configure:7618: found /usr/bin/ar
configure:7629: result: ar
configure:7707: checking for strip
configure:7723: found /usr/bin/strip
configure:7734: result: strip
configure:7806: checking for ranlib
configure:7822: found /usr/bin/ranlib
configure:7833: result: ranlib
configure:7923: checking command to parse /usr/bin/nm -B output from gcc object
configure:8041: g++ -c -g -O2 conftest.cpp >&5
configure:8044: $? = 0
configure:8048: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' \> conftest.nm
configure:8051: $? = 0
configure:8105: g++ -o conftest -g -O2 conftest.cpp conftstm.o >&5
configure:8108: $? = 0
configure:8146: result: ok
configure:8242: g++ -c -g -O2 conftest.cpp >&5
configure:8245: $? = 0
configure:9012: checking for dlfcn.h
configure:9033: g++ -c -g -O2 conftest.cpp >&5
configure:9040: $? = 0
configure:9057: result: yes
configure:9184: checking for C++ compiler version
configure:9192: g++ --version >&5
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE[\code]
configure:9196: $? = 0
configure:9203: g++ -v >&5
Thread model: posix
configure:9207: $? = 0
configure:9214: g++ -V >&5
configure:9218: $? = 1
configure:9221: checking whether we are using the GNU C++ compiler
configure:9274: result: yes
configure:9283: checking whether g++ accepts -g
configure:9421: result: yes
configure:9446: checking dependency style of g++
configure:9537: result: gcc3
configure:9560: checking how to run the C++ preprocessor
configure:9674: result: g++ -E
configure:9703: g++ -E conftest.cpp
configure:9710: $? = 0
configure:9741: g++ -E conftest.cpp
conftest.cpp:38:28: error: ac_nonexistent.h: No such file or directory
configure:9748: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
| #define HAVE_SSTREAM 1
| #define HAVE_NAMESPACES /**/
| #define HAVE_STD_IOSTREAM /**/
| #define HAVE_DLFCN_H 1
configure:9899: checking for objdir
configure:9914: result: .libs
configure:10206: checking if gcc supports -fno-rtti -fno-exceptions
configure:10224: gcc -c -g -O2 -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option "-fno-rtti" is valid for C++/ObjC++ but not for C
configure:10228: $? = 0
configure:10241: result: no
configure:10261: checking for gcc option to produce PIC
configure:10533: result: -fPIC -DPIC
configure:10545: checking if gcc PIC flag -fPIC -DPIC works
configure:10563: gcc -c -g -O2 -fPIC -DPIC -DPIC conftest.c >&5
configure:10567: $? = 0
configure:10580: result: yes
configure:10604: checking if gcc static flag -static works
configure:10632: result: yes
configure:10647: checking if gcc supports -c -o file.o
configure:10668: gcc -c -g -O2 -o out/conftest2.o conftest.c >&5
configure:10672: $? = 0
configure:10694: result: yes
configure:10702: checking if gcc supports -c -o file.o
configure:10749: result: yes
configure:10782: checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:11860: result: yes
configure:11897: checking whether -lc should be explicitly linked in
configure:11902: gcc -c -g -O2 conftest.c >&5
configure:11905: $? = 0
configure:11920: gcc -shared conftest.o -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /bin/grep -lc \>/dev/null 2\>\&1
configure:11923: $? = 0
configure:11935: result: no
configure:12099: checking dynamic linker characteristics
configure:12542: gcc -o conftest -g -O2 -Wl,-rpath -Wl,/foo conftest.c >&5
configure:12549: $? = 0
configure:12794: result: GNU/Linux ld.so
configure:12896: checking how to hardcode library paths into programs
configure:12921: result: immediate
configure:13044: checking for shl_load
configure:13100: gcc -o conftest -g -O2 conftest.c >&5
/tmp/ccSd88U8.o: In function `main':
/home/conrad/source/free-cad/trunk/conftest.c:73: undefined reference to `shl_load'
collect2: ld returned 1 exit status
configure:13107: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
| #define LT_OBJDIR ".libs/"
| /* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
| For example, HP-UX 11i <limits.h> declares gettimeofday. */
| #define shl_load innocuous_shl_load
| /* System header to define __stub macros and hopefully few prototypes,
| which can conflict with char shl_load (); below.
| Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
| <limits.h> exists even on freestanding compilers. */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef shl_load
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char shl_load ();
| /* The GNU C library defines this for functions which it implements
| to always fail with ENOSYS. Some functions are actually named
| something starting with __ and the normal name is an alias. */
| #if defined __stub_shl_load || defined __stub___shl_load
| choke me
| #endif
| int
| main ()
| return shl_load ();
| return 0;
configure:13127: result: no
configure:13132: checking for shl_load in -ldld
configure:13167: gcc -o conftest -g -O2 conftest.c -ldld >&5
/usr/bin/ld: cannot find -ldld
configure:13174: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char shl_load ();
| int
| main ()
| return shl_load ();
| return 0;
configure:13195: result: no
configure:13200: checking for dlopen
configure:13256: gcc -o conftest -g -O2 conftest.c >&5
/tmp/ccKjXbsC.o: In function `main':
/home/conrad/source/free-cad/trunk/conftest.c:73: undefined reference to `dlopen'
configure:13263: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
| /* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
| #define dlopen innocuous_dlopen
| which can conflict with char dlopen (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef dlopen
| #ifdef __cplusplus
| extern "C"
| #endif
| char dlopen ();
| #if defined __stub_dlopen || defined __stub___dlopen
| choke me
| #endif
| int
| main ()
| return dlopen ();
| return 0;
configure:13283: result: no
configure:13288: checking for dlopen in -ldl
configure:13323: gcc -o conftest -g -O2 conftest.c -ldl >&5
configure:13330: $? = 0
configure:13351: result: yes
configure:13528: checking whether a program can dlopen itself
configure:13598: gcc -o conftest -g -O2 -DHAVE_DLFCN_H -Wl,--export-dynamic conftest.c -ldl >&5
configure:13601: $? = 0
configure:13619: result: yes
configure:13624: checking whether a statically linked program can dlopen itself
configure:13694: gcc -o conftest -g -O2 -DHAVE_DLFCN_H -Wl,--export-dynamic -static conftest.c -ldl >&5
/tmp/ccA8tnxo.o: In function `main':
/home/conrad/source/free-cad/trunk/configure:13678: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
configure:13697: $? = 0
/lib/: cannot read file data: Is a directory
configure:13715: result: no
configure:13754: checking whether stripping libraries is possible
configure:13759: result: yes
configure:13794: checking if libtool supports shared libraries
configure:13796: result: yes
configure:13799: checking whether to build shared libraries
configure:13820: result: yes
configure:13823: checking whether to build static libraries
configure:13827: result: no
configure:13977: checking for ld used by g++
configure:14044: result: /usr/bin/ld -m elf_x86_64
configure:14053: checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld
configure:14068: result: yes
configure:14123: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:15098: result: yes
configure:15126: g++ -c -g -O2 conftest.cpp >&5
configure:15129: $? = 0
configure:15311: checking for g++ option to produce PIC
configure:15628: result: -fPIC -DPIC
configure:15637: checking if g++ PIC flag -fPIC -DPIC works
configure:15655: g++ -c -g -O2 -fPIC -DPIC -DPIC conftest.cpp >&5
configure:15659: $? = 0
configure:15672: result: yes
configure:15693: checking if g++ static flag -static works
configure:15721: result: yes
configure:15733: checking if g++ supports -c -o file.o
configure:15754: g++ -c -g -O2 -o out/conftest2.o conftest.cpp >&5
configure:15758: $? = 0
configure:15780: result: yes
configure:15785: checking if g++ supports -c -o file.o
configure:15832: result: yes
configure:15862: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:15891: result: yes
configure:16028: checking dynamic linker characteristics
configure:16419: g++ -o conftest -g -O2 -Wl,-rpath -Wl,/foo conftest.cpp >&5
configure:16426: $? = 0
configure:16671: result: GNU/Linux ld.so
configure:16722: checking how to hardcode library paths into programs
configure:16747: result: immediate
configure:16805: checking whether ln -s works
configure:16809: result: yes
configure:16819: checking for swig
configure:16837: found /usr/bin/swig
configure:16850: result: /usr/bin/swig
configure:16955: checking for inflate in -lz
configure:16990: g++ -o conftest -g -O2 conftest.cpp -lz >&5
configure:16997: $? = 0
configure:17018: result: yes
configure:17070: checking for a Python interpreter with version >= 2.5
configure:17085: python -c import sys, string # split strings by '.' and convert to numeric. Append some zeros # because we need at least 4 digits for the hex conversion. minver = map(int, string.split('2.5', '.')) + [0, 0, 0] minverhex = 0 for i in xrange(0, 4): minverhex = (minverhex << 8) + minver[i] sys.exit(sys.hexversion < minverhex)
configure:17088: $? = 0
configure:17095: result: python
configure:17103: checking for python
configure:17121: found /usr/bin/python
configure:17133: result: /usr/bin/python
configure:17153: checking for python version
configure:17160: result: 2.5
configure:17172: checking for python platform
configure:17179: result: linux2
configure:17186: checking for python script directory
configure:17194: result: ${prefix}/lib/python2.5/site-packages
configure:17203: checking for python extension module directory
configure:17211: result: ${exec_prefix}/lib/python2.5/site-packages
configure:17262: checking Python.h usability
configure:17279: g++ -c -g -O2 -I/usr/include/python2.5 conftest.cpp >&5
configure:17286: $? = 0
configure:17300: result: yes
configure:17304: checking Python.h presence
configure:17319: g++ -E -I/usr/include/python2.5 conftest.cpp
configure:17326: $? = 0
configure:17340: result: yes
configure:17373: checking for Python.h
configure:17380: result: yes
configure:17386: checking for libpython2.5
configure:17412: g++ -o conftest -g -O2 -I/usr/include/python2.5 -L/usr/lib conftest.cpp -lpython2.5 >&5
configure:17419: $? = 0
configure:17428: result: yes
configure:17466: checking for xerces-c
configure:17478: checking for /usr/include/xercesc
configure:17495: result: yes
configure:17553: checking xercesc/framework/XMLBuffer.hpp usability
configure:17570: g++ -c -g -O2 -I/usr/include conftest.cpp >&5
configure:17577: $? = 0
configure:17591: result: yes
configure:17595: checking xercesc/framework/XMLBuffer.hpp presence
configure:17610: g++ -E -I/usr/include conftest.cpp
configure:17617: $? = 0
configure:17631: result: yes
configure:17664: checking for xercesc/framework/XMLBuffer.hpp
configure:17671: result: yes
configure:17677: checking whether xerces lib is available
configure:17701: g++ -o conftest -g -O2 -I/usr/include -L/usr/lib conftest.cpp -lxerces-c >&5
configure:17708: $? = 0
configure:17717: result: yes
configure:17754: checking for boost
configure:17808: g++ -o conftest -g -O2 -I/usr/include -L/usr/lib conftest.cpp -lboost_program_options >&5
/usr/bin/ld: cannot find -lboost_program_options
configure:17815: $? = 1
| /* confdefs.h. */
| #define HAVE_IOS 1
| #define HAVE_GETENVIRONMENTVARIABLE 1
| #define HAVE_GL_GL_H 1
| #define HAVE_QGLFORMAT_EQ_OP 1
| #define HAVE_QGLFORMAT_SETOVERLAY 1
| #define HAVE_QGLWIDGET_SETAUTOBUFFERSWAP 1
| #define HAVE_QT_KEYPAD_DEFINE 1
| #define HAVE_QWIDGET_SHOWFULLSCREEN 1
| #define USE_STD_IOSTREAM 1
| #include <boost/program_options.hpp>
| int
| main ()
| namespace po = boost::program_options;
| po::options_description generic("Generic options");
| generic.add_options()
| ("version,v", "print version string")
| ("help", "produce help message");
| return 0;
configure:17829: error: failed
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_cxx_have_std_iostream=yes
ac_cv_cxx_namespaces=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_opencv_CFLAGS_set=
ac_cv_env_opencv_CFLAGS_value=
ac_cv_env_opencv_LIBS_set=
ac_cv_env_opencv_LIBS_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_file__usr_include_xercesc=yes
ac_cv_func_dlopen=no
ac_cv_func_shl_load=no
ac_cv_header_Python_h=yes
ac_cv_header_bits_sigset_h=yes
ac_cv_header_bstring_h=no
ac_cv_header_dlfcn_h=yes
ac_cv_header_float_h=yes
ac_cv_header_fstream=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_iomanip=yes
ac_cv_header_iomanip_h=no
ac_cv_header_ios=yes
ac_cv_header_iostream=yes
ac_cv_header_istream=yes
ac_cv_header_libc_h=no
ac_cv_header_limits_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_ostream=yes
ac_cv_header_siginfo_h=no
ac_cv_header_sstream=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_filio_h=no
ac_cv_header_sys_mman_h=yes
ac_cv_header_sys_select_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_values_h=yes
ac_cv_header_xercesc_framework_XMLBuffer_hpp=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_dl_dlopen=yes
ac_cv_lib_dld_shl_load=no
ac_cv_lib_z_inflate=yes
ac_cv_objext=o
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_FGREP='/bin/grep -F'
ac_cv_path_GREP=/bin/grep
ac_cv_path_PYTHON=/usr/bin/python
ac_cv_path_SED=/bin/sed
ac_cv_path_SWIG=/usr/bin/swig
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_make_make_set=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_pathless_PYTHON=python
am_cv_prog_tar_ustar=gnutar
am_cv_python_platform=linux2
am_cv_python_pyexecdir='${exec_prefix}/lib/python2.5/site-packages'
am_cv_python_pythondir='${prefix}/lib/python2.5/site-packages'
am_cv_python_version=2.5
fc_cv_lib_py_avail=yes
fc_cv_lib_xer_avail=yes
lt_cv_deplibs_check_method=pass_all
lt_cv_dlopen=dlopen
lt_cv_dlopen_libs=-ldl
lt_cv_dlopen_self=yes
lt_cv_dlopen_self_static=no
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX='/usr/bin/ld -m elf_x86_64'
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=yes
lt_cv_prog_compiler_static_works_CXX=yes
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=1572864
## Output variables. ##
ACLOCAL='${SHELL} /home/conrad/source/free-cad/trunk/missing --run aclocal-1.10'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/conrad/source/free-cad/trunk/missing --run tar'
AR='ar'
AUTOCONF='${SHELL} /home/conrad/source/free-cad/trunk/missing --run autoconf'
AUTOHEADER='${SHELL} /home/conrad/source/free-cad/trunk/missing --run autoheader'
AUTOMAKE='${SHELL} /home/conrad/source/free-cad/trunk/missing --run automake-1.10'
AWK='gawk'
BOOST_FILESYSTEM_LIB=''
BOOST_PROGOPTIONS_LIB=''
BOOST_REGEX_LIB=''
BOOST_SIGNALS_LIB=''
BOOST_SYSTEM_LIB=''
CC='gcc'
CCDEPMODE='depmode=gcc3'
CFLAGS='-g -O2'
CPPFLAGS=' -I/usr/include'
CXX='g++'
CXXCPP='g++ -E'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-g -O2'
CYGPATH_W='echo'
DEFS=''
DEPDIR='.deps'
DISTCHECK_CONFIGURE_FLAGS=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
GL_LIBS=''
GREP='/bin/grep'
GTSCONFIG=''
GTS_CFLAGS=''
GTS_LIBS=''
HAVE_GTS_FALSE=''
HAVE_GTS_TRUE=''
HAVE_OPENCASCADE_FALSE=''
HAVE_OPENCASCADE_TRUE=''
HAVE_OPENCV_FALSE=''
HAVE_OPENCV_TRUE=''
HAVE_SWIG='1'
HAVE_SWIG_FOUND_FALSE='#'
HAVE_SWIG_FOUND_TRUE=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LD='/usr/bin/ld -m elf_x86_64'
LDFLAGS=' -L/usr/lib'
LIBOBJS=''
LIBS='-lboost_program_options'
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIB_AGE='0'
LIB_CURRENT='2'
LIB_REVISION='0'
LIPO=''
LN_S='ln -s'
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/conrad/source/free-cad/trunk/missing --run makeinfo'
MKDIR_P='/bin/mkdir -p'
NM='/usr/bin/nm -B'
NMEDIT=''
OBJDUMP='objdump'
OBJEXT='o'
OCC_INC=''
OCC_LIB=''
OCC_VERSION6_FALSE=''
OCC_VERSION6_TRUE=''
OTOOL64=''
OTOOL=''
PACKAGE='FreeCAD'
PACKAGE_BUGREPORT='wmayer@users.sourceforge.net'
PACKAGE_NAME='FreeCAD'
PACKAGE_STRING='FreeCAD 0.7.2008'
PACKAGE_TARNAME='FreeCAD'
PACKAGE_VERSION='0.7.2008'
PATH_SEPARATOR=':'
PKG_CONFIG=''
PYTHON='/usr/bin/python'
PYTHON_EXEC_PREFIX='${exec_prefix}'
PYTHON_LIB='python2.5'
PYTHON_PLATFORM='linux2'
PYTHON_PREFIX='${prefix}'
PYTHON_VERSION='2.5'
QT_CXXFLAGS=''
QT_DIR=''
QT_LIBS=''
QT_MOC=''
QT_RCC=''
QT_UIC=''
RANLIB='ranlib'
SED='/bin/sed'
SET_MAKE=''
SHELL='/bin/sh'
STRIP='strip'
SWIG='/usr/bin/swig'
VERSION='0.7.2008'
XMKMF=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=''
ac_ct_CC='gcc'
ac_ct_CXX='g++'
ac_ct_DUMPBIN=''
all_includes=' -I/usr/include/python2.5 -I/usr/include'
all_libraries=' -L/usr/lib -L/usr/lib'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='tar --format=ustar -chf - "$$tardir"'
am__untar='tar -xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='$(SHELL) /home/conrad/source/free-cad/trunk/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
lt_ECHO='echo'
mandir='${datarootdir}/man'
mkdir_p='/bin/mkdir -p'
oldincludedir='/usr/include'
opencv_CFLAGS=''
opencv_LIBS=''
pdfdir='${docdir}'
pkgpyexecdir='${pyexecdir}/FreeCAD'
pkgpythondir='${pythondir}/FreeCAD'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sim_ac_coin_configcmd=''
sim_ac_coin_cppflags=''
sim_ac_coin_includedir=''
sim_ac_coin_ldflags=''
sim_ac_coin_libs=''
sim_ac_soqt_configcmd=''
sim_ac_soqt_cppflags=''
sim_ac_soqt_includedir=''
sim_ac_soqt_ldflags=''
sim_ac_soqt_libs=''
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
#define HAVE_IOS 1
configure: exit 1
