[Archlinux] build error
yangtsesu
Postby yangtsesu » Wed Dec 25, 2013 9:27 am
use AUR freecad-git
https://aur.archlinux.org/packages/freecad-git/
Archlinux
[ 57%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/PreCompiled.cpp.o
Linking CXX shared library ../../lib/libFreeCADGui.so
[ 57%] Built target FreeCADGui
Makefile:116: recipe for target 'all' failed
make: *** [all] Error 2
Site Admin
Re: [Archlinux] build error
Postby wmayer » Wed Dec 25, 2013 11:51 am
That's not much information you give here. Can you upload the generated Makefile so we can see how it looks like around line 116?
yangtsesu
Postby yangtsesu » Wed Dec 25, 2013 1:31 pm
Site Admin
Postby wmayer » Fri Dec 27, 2013 10:31 am
It looks like you posted the wrong files. In your build directory there must be the sub-directories src/Gui which also has a Makefile. Besides this, maybe it's a problem with CMake. Is there a chance to test with an older version of CMake?
yangtsesu
Postby yangtsesu » Fri Dec 27, 2013 12:24 pm
Site Admin
Postby wmayer » Fri Dec 27, 2013 2:10 pm
I have looked through the relevant files but didn't get a hint to the actual problem. I wonder whether cmake doesn't write this out somewhere. Do you get some additional information in the terminal window? At least the generated Makefile around line 116 looks correct to me because I have quite the same here.
yangtsesu
Postby yangtsesu » Sat Dec 28, 2013 2:36 am
I am so sorry.
Error message is here.
[ 42%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/DriverDAT.dir/src/DriverDAT/DriverDAT_W_SMESHDS_Document.cpp.o
[ 42%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/DriverDAT.dir/src/DriverDAT/DriverDAT_W_SMESHDS_Mesh.cpp.o
Linking CXX shared library ../../../lib/DriverDAT.so
[ 42%] Generating moc_ReportView.cpp
/home/yangtse/aur/freecad-git/src/freecad/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPyImp.cpp: In member function 'PyObject* Part::BRepOffsetAPI_MakePipeShellPy::setAuxiliarySpine(PyObject*)':
/home/yangtse/aur/freecad-git/src/freecad/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPyImp.cpp:128:74: error: invalid conversion from 'Standard_Boolean {aka unsigned int}' to 'BRepFill_TypeOfContact' [-fpermissive]
         PyObject_IsTrue(keep) ? Standard_True : Standard_False);
In file included from /home/yangtse/aur/freecad-git/src/freecad/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPyImp.cpp:31:0:
/opt/opencascade/inc/BRepOffsetAPI_MakePipeShell.hxx:124:8: error:   initializing argument 3 of 'void BRepOffsetAPI_MakePipeShell::SetMode(const TopoDS_Wire&, Standard_Boolean, BRepFill_TypeOfContact)' [-fpermissive]
   Standard_EXPORT     void SetMode(const TopoDS_Wire& AuxiliarySpine,const Standard_Boolean CurvilinearEquivalence,const BRepFill_TypeOfContact KeepContact = BRepFill_NoContact) ;
src/Mod/Part/App/CMakeFiles/Part.dir/build.make:1840: recipe for target 'src/Mod/Part/App/CMakeFiles/Part.dir/BRepOffsetAPI_MakePipeShellPyImp.cpp.o' failed
make[2]: *** [src/Mod/Part/App/CMakeFiles/Part.dir/BRepOffsetAPI_MakePipeShellPyImp.cpp.o] Error 1
CMakeFiles/Makefile2:1603: recipe for target 'src/Mod/Part/App/CMakeFiles/Part.dir/all' failed
make[1]: *** [src/Mod/Part/App/CMakeFiles/Part.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 42%] Generating moc_SelectionView.cpp
yangtsesu
Postby yangtsesu » Sat Dec 28, 2013 2:40 am
cmake 2.8.12.1
Site Admin
Postby wmayer » Sat Dec 28, 2013 10:00 am
Here is the code snippet that fails:
PyObject* BRepOffsetAPI_MakePipeShellPy::setAuxiliarySpine(PyObject *args)
    PyObject *spine, *curv, *keep;
    if (!PyArg_ParseTuple(args, "O!O!O!",&Part::TopoShapePy::Type,&spine
                                        ,&PyBool_Type,&curv
                                        ,&PyBool_Type,&keep))
        return 0;
    const TopoDS_Shape& s = static_cast<Part::TopoShapePy*>(spine)->getTopoShapePtr()->_Shape;
    if (s.IsNull() || s.ShapeType() != TopAbs_WIRE) {
        PyErr_SetString(PyExc_TypeError, "spine is not a wire");
        return 0;
    this->getBRepOffsetAPI_MakePipeShellPtr()->SetMode(
        TopoDS::Wire(s),
        PyObject_IsTrue(curv) ? Standard_True : Standard_False,
    Py_Return;
And here is the interface of SetMode:
  Standard_EXPORT     void SetMode(const TopoDS_Wire& AuxiliarySpine,const Standard_Boolean CurvilinearEquivalence,const Standard_Boolean KeepContact = Standard_False) ;
This is for OpenCascade version 6.6.0 and older. Which version of OpenCascade do you have?
Site Admin
Postby wmayer » Sat Dec 28, 2013 11:24 am
I hope git c1d14ea fixes the problem.
