i get the following error when i try to build freecad from the arch linux AUR (which uses the svn repository of freecad):
make[6]: Entering directory `/var/abs/local/yaourtbuild/freecad-svn/src/freecad/src/Mod/Mesh/App'
/bin/sh ../../../../libtool --tag=CXX --mode=link g++ -D_OCC64 -Wno-deprecated -frtti -L../../../Base -L../../../App -L/usr/lib -L/usr/lib/ -L/usr/lib -L -L/usr/lib -lgts -lglib-2.0 -lm -version-info 2:0:0 -lpthread -o libMesh.la -rpath /usr/Mod/Mesh libMesh_la-Algorithm.lo libMesh_la-Approximation.lo libMesh_la-Builder.lo libMesh_la-Definitions.lo libMesh_la-Degeneration.lo libMesh_la-Elements.lo libMesh_la-Evaluation.lo libMesh_la-Grid.lo libMesh_la-Info.lo libMesh_la-MeshKernel.lo libMesh_la-MeshIO.lo libMesh_la-Projection.lo libMesh_la-SetOperations.lo libMesh_la-Triangulation.lo libMesh_la-Tools.lo libMesh_la-TopoAlgorithm.lo libMesh_la-Visitor.lo libMesh_la-Wm4ApprCylinderFit3.lo libMesh_la-Wm4ApprLineFit3.lo libMesh_la-Wm4ApprPlaneFit3.lo libMesh_la-Wm4ApprPolyFit3.lo libMesh_la-Wm4ApprQuadraticFit3.lo libMesh_la-Wm4ApprSphereFit3.lo libMesh_la-Wm4DelPolygonEdge.lo libMesh_la-Wm4DelPolyhedronFace.lo libMesh_la-Wm4DelTetrahedron.lo libMesh_la-Wm4DelTriangle.lo libMesh_la-Wm4Delaunay.lo libMesh_la-Wm4Delaunay1.lo libMesh_la-Wm4Delaunay2.lo libMesh_la-Wm4Delaunay3.lo libMesh_la-Wm4DistLine3Segment3.lo libMesh_la-Wm4DistLine3Triangle3.lo libMesh_la-Wm4DistSegment3Segment3.lo libMesh_la-Wm4DistSegment3Triangle3.lo libMesh_la-Wm4DistVector3Plane3.lo libMesh_la-Wm4DistVector3Segment3.lo libMesh_la-Wm4DistVector3Triangle3.lo libMesh_la-Wm4Distance.lo libMesh_la-Wm4ETManifoldMesh.lo libMesh_la-Wm4Eigen.lo libMesh_la-Wm4FoundationPCH.lo libMesh_la-Wm4ImplicitSurface.lo libMesh_la-Wm4Intersector.lo libMesh_la-Wm4Intersector1.lo libMesh_la-Wm4IntrLine3Box3.lo libMesh_la-Wm4IntrLine3Plane3.lo libMesh_la-Wm4IntrSegment3Box3.lo libMesh_la-Wm4IntrSegment3Plane3.lo libMesh_la-Wm4IntrTriangle2Triangle2.lo libMesh_la-Wm4IntrTriangle3Triangle3.lo libMesh_la-Wm4LinearSystem.lo libMesh_la-Wm4Math.lo libMesh_la-Wm4Matrix2.lo libMesh_la-Wm4Matrix3.lo libMesh_la-Wm4Matrix4.lo libMesh_la-Wm4Memory.lo libMesh_la-Wm4MeshCurvature.lo libMesh_la-Wm4MeshSmoother.lo libMesh_la-Wm4ParametricSurface.lo libMesh_la-Wm4PolynomialRoots.lo libMesh_la-Wm4QuadricSurface.lo libMesh_la-Wm4Surface.lo libMesh_la-Wm4System.lo libMesh_la-Wm4TriangulateEC.lo libMesh_la-Wm4VEManifoldMesh.lo libMesh_la-Wm4Vector2.lo libMesh_la-Wm4Vector3.lo libMesh_la-Wm4Vector4.lo libMesh_la-AppMeshPy.lo libMesh_la-Doxygen.lo libMesh_la-Facet.lo libMesh_la-FacetPyImp.lo libMesh_la-FeatureMeshCurvature.lo libMesh_la-FeatureMeshExport.lo libMesh_la-FeatureMeshDefects.lo libMesh_la-FeatureMeshImport.lo libMesh_la-FeatureMeshSegmentByMesh.lo libMesh_la-FeatureMeshSetOperations.lo libMesh_la-FeatureMeshSolid.lo libMesh_la-FeatureMeshTransform.lo libMesh_la-FeatureMeshTransformDemolding.lo libMesh_la-Mesh.lo libMesh_la-MeshFeature.lo libMesh_la-MeshFeaturePyImp.lo libMesh_la-MeshPointPyImp.lo libMesh_la-MeshProperties.lo libMesh_la-MeshPyImp.lo libMesh_la-GTSAlgos.lo libMesh_la-Segment.lo libMesh_la-PreCompiled.lo -lboost_filesystem-mt -lboost_regex-mt -lboost_system-mt -lxerces-c -lpython2.6 -lFreeCADBase -lFreeCADApp
libtool: link: require no space between `-L' and `-L/usr/lib'
make[6]: *** [libMesh.la] Fehler 1
make[6]: Leaving directory `/var/abs/local/yaourtbuild/freecad-svn/src/freecad/src/Mod/Mesh/App'
make[5]: *** [all] Fehler 2
make[5]: Leaving directory `/var/abs/local/yaourtbuild/freecad-svn/src/freecad/src/Mod/Mesh/App'
make[4]: *** [all-recursive] Fehler 1
make[4]: Leaving directory `/var/abs/local/yaourtbuild/freecad-svn/src/freecad/src/Mod/Mesh'
make[3]: *** [all-recursive] Fehler 1
make[3]: Leaving directory `/var/abs/local/yaourtbuild/freecad-svn/src/freecad/src/Mod'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/var/abs/local/yaourtbuild/freecad-svn/src/freecad/src'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/var/abs/local/yaourtbuild/freecad-svn/src/freecad'
make: *** [all] Fehler 2
Does anybody know how to fix this?
Thank you
