Hi
Yesterday I downloaded freecad_0.8.2237-1jaunty1_i386.deb
When trying to install it the package manager claimed the package was corrupt. A redownload gave the same result. Unfortunately there is no md5sum or similar to verify if it's a problem of the package or an error during download.
Anyway, I tried instead to compile from source. After a lot of installing missing packages both configure, make and make install finished successfully. However the software doesnt seem to work as it should. I cant seem to be able to actually modify (draw) in a scetch. Also the self test reports the two following errors.
-- Error
File "/usr/lib/python2.6/unittest.py", line 279, in run
testMethod()
File "/home/stefan/FreeCAD/Mod/Mesh/MeshTestsApp.py", line 114, in testPrimitiveCount
from pivy import coin, sogui; import FreeCADGui
ImportError: No module named pivy
-- Error
testMethod()
File "/home/stefan/FreeCAD/Mod/Mesh/MeshTestsApp.py", line 90, in testRayPick
-- Failure
testMethod()
File "/home/stefan/FreeCAD/Mod/Test/Workbench.py", line 43, in testActivate
self.failUnless(FreeCADGui.activeWorkbench().name()==i, "Test on activating workbench failed")
File "/usr/lib/python2.6/unittest.py", line 325, in failUnless
if not expr: raise self.failureException, msg
AssertionError: Test on activating workbench failed
Also cmdline also mentiones the lack of pivy module.
The readme file doesnt seem to mention these errors or where to get the pivy module.
My system is a laptop with ATI Graphics running (x)ubuntu 9.04
Jaunty package broken and compile not functional
Re: Jaunty package broken and compile not functional
I have tested the package right now and it installed properly. Maybe you should choose another download mirror on SF.
Unfortunately, there is no official .deb package for pivy available. For Jaunty 32-bit I'm building one at the moment and will upload it ASAP.
However, at http://git.debian.org/?p=collab-maint/pivy.git you'll find the sources which must be adjusted to work on Jaunty because it uses different Coin/SoQt packages than Debian testing.
Werner
Werner
The pivy package for Jaunty is on the server now. You'll find it here: https://sourceforge.net/projects/free-c ... b/download
Thanks a bunch for the Pivy deb
Didnt have time to test before now, but after installing it and Python-QT4 all selftests seem to complete.
Thanks for the great support and a great start of fixing a sorely missing black hole of LOSS, a proper Engineering CAD util
