Announcement: new LibPacks are available
peterl94
Postby peterl94 » Wed Dec 03, 2014 6:05 am
Just thought I would make a post here, since I don't think I'll have time to update the wiki this week.
There are new LibPacks available for VS 2008, VS 2012, and VS 2013: FreeCAD LibPack/ (version 11.0). Unless you use LibPack 9.0, you will need to use one of these if you want to do a complete build. There are only 64-bit versions right now, but I'll be uploading 32-bit versions for VS 2008 and VS 2013 soon. LibPack 11.0 contains the following libraries:
boost          1.55
coin           4.0.0a
eigen          3.2.1
flann          1.8.4
freeimage      3.15.4
freetype       2.5.2
libpng         1.6.15
matplotlib     1.4.2
netgen         5.1
numpy          1.9.1
oce            0.16
openssl        1.0.1h
pcl            1.7.2
pivy           HEAD
pthreads       2.9.1
pyside         1.2.2
pyside_tools   0.2.15
python         2.7.8
qhull          2012.1
qt             4.8.6
setuptools     5.4.1
shiboken       1.2.2
sqlite3        3.8.5
swig           1.3.40
tcl            8.6.1
tk             8.6.1
xerces_c       3.1.1
zlib           1.2.8
yorik
Site Admin
Re: Announcement: new LibPacks are available
Postby yorik » Wed Dec 03, 2014 1:04 pm
Thanks for your hard work peter!
sgrogan
Postby sgrogan » Wed Dec 03, 2014 1:59 pm
@Peterl94
Thanks for the effort.
I am working on a procedure to build from scratch with links to all the required stuff 7zip,Cmake etc. I hope to finish this weekend and ask for Wiki privileges. If it can wait til then I can handle the Wiki. You've done enough.
Oh Yea.
I've been building from Master daily with no hitches with VS2013 and your new Libpack.
peterl94
Postby peterl94 » Sat Dec 06, 2014 2:35 am
32-bit VS 2009 and 2013 versions are up now.
sgrogan
Postby sgrogan » Sat Dec 06, 2014 3:56 am
VS2013 x86 release
perfect :)
microelly2
Postby microelly2 » Sat Dec 06, 2014 9:53 am
Thank you Peter. Its nearly complete.
Here my result -
1. run - an error may be that the order in a makefile should be changed
2.run - there is still one error related to coin.
1. Run
Linking...
26>LINK : fatal error LNK1181: cannot open input file '..\..\..\lib\Release\SMDS.lib'
26>Build log was saved at "file://e:\built_freetype\src\3rdParty\salomesmesh\SMESH.dir\Release\BuildLog.htm"
2. Run
5>Compiling...
2>Unit.cpp
6>Build log was saved at "file://e:\built_freetype\src\Mod\Draft\Draft.dir\Release\BuildLog.htm"
6>Draft - 0 error(s), 0 warning(s)
5>coin_wrap.cpp
5>E:\freecad\freecadlibs\include\Inventor/system/inttypes.h(99) : warning C4005: 'HAVE_INTPTR_T' : macro redefinition
5> e:\freecad\freecadlibs\include\python2.7\pyconfig.h(396) : see previous definition of 'HAVE_INTPTR_T'
5>E:\freecad\freecadlibs\include\Inventor/system/inttypes.h(100) : warning C4005: 'HAVE_UINTPTR_T' : macro redefinition
5> e:\freecad\freecadlibs\include\python2.7\pyconfig.h(393) : see previous definition of 'HAVE_UINTPTR_T'
5>E:\freecad\freecadlibs\include\Inventor/elements/SoGLTexture3EnabledElement.h(36) : fatal error C1189: #error : Deprecated: use SoMultiTextureEnabledElement instead
5>Build log was saved at "file://e:\built_freetype\src\3rdParty\Pivy-0.5\coin.dir\Release\BuildLog.htm"
5>coin - 1 error(s), 2 warning(s)
========== Build: 55 succeeded, 1 failed, 15 up-to-date, 3 skipped ==========
OS: Windows 7
Word size of FreeCAD: 32-bit
Version: 0.15.4244 (Git)
Hash: 49646282910aeef73db44943b88df06f0957422c
Python version: 2.7.8
Qt version: 4.8.6
Site Admin
Postby wmayer » Sat Dec 06, 2014 10:04 am
Does the libpack offer a pre-built version of pivy? IMO, under Windows pivy should be offered by the libpacks so that we can remove it from our git repository.
jmaustpc
Postby jmaustpc » Sat Dec 06, 2014 11:15 am
Perter lists Pivy (-version head) in the list of the libpack contents a few posts back..... but currently to use that "libpack Pivy" rather than the Pivy in the FreeCAD source code, you have to tick "use external pivy" while configuring in cmake-gui.
wmayer wrote: IMO, under Windows pivy should be offered by the libpacks so that we can remove it from our git repository.
Sound like a good idea, but if that can't be done for any reason, could we make "use external pivy" the cmake default?
Jim
Site Admin
Postby wmayer » Sat Dec 06, 2014 12:30 pm
Sure.
sgrogan
Postby sgrogan » Sat Dec 06, 2014 12:56 pm
Using VS2013 x86 release build form scratch I do not get the error microelly2 does
========= Build: 70 succeeded, 0 failed, 0 up-to-date, 3 skipped ==========
OS: Windows 7
Qt version: 4.8.6
OCC version: 6.7.1
