Request for more options for text object's FontName.
Mark Szlazak
Post by Mark Szlazak »
Seems like only Arial can be used for a text object's ViewObject.FontName. Can more fonts be added?
Re: Request for more options for text object's FontName.
Post by yorik »
You can use any font present on your system... Just set the name there instead of Arial..
Jee-Bee
Post by Jee-Bee »
Is tit possible to make a dropdown menu here that shows the presented fonts. I have no clue what fonts are all installed on all/ any of mys system(s).
Not talking about what type fonts were accepted. I can imagine that a few of my \latex fonts are not accepted...
Post by yorik »
Jee-Bee wrote:Is tit possible to make a dropdown menu here that shows the presented fonts.
Yes, that is on my radar for some time. Qt provides that already, we would just need to implement a new property type.
However, before that I would lie to find a way to unify the different font systems, for ex. Draft ShapeString uses a direct path to a ttf file, and I haven't found a relaiable way yet to convert between ttf file path and font name. Plus, coin also accepts not only font names but families (Arial,Sans Serif,sans) or even styles (Arial:bold). Not too sure yet of how to unify all that...
Mark Szlazak
Thank you Yorik. I must be setting it wrong in script because none of these work:
txt.ViewObject.FontName = "Times Roman" (or "Courier" or "Script", etc)
Also, font styles setting would really be nice to have!
BTW, I am in the Part workbench. How do i find out what fonts work?
Post by wmayer »
We have the type PropertyFont for long time.
obj=App.ActiveDocument.addObject("App::FeaturePython")
obj.addProperty("App::PropertyFont","Font")
The property editor shows a combo box with all the font names.
Post by yorik »
:D one more feature that was there since the beginning and that you only discover years later
wandererfan
Post by wandererfan »
yorik wrote:However, before that I would lie to find a way to unify the different font systems, for ex. Draft ShapeString uses a direct path to a ttf file, and I haven't found a relaiable way yet to convert between ttf file path and font name.
for X11 (Linux and ?OSX?)
//this:
QString family = QString::fromUtf8("Arial");
QFont font(family);
font.setItalic(true);
FT_Face FTFont = font.freetypeFace();
//can replace this:
error = FT_New_Face(FTLib,FontSpec,FaceIndex, &FTFont);
These posts are about the same problem in Windows.
https://stackoverflow.com/questions/167 ... ndle-hfont
https://stackoverflow.com/questions/457 ... old-italic
https://stackoverflow.com/questions/113 ... -c-windows
Mark Szlazak
Thanks wmayer but I get nothing happening when i tried these in the console. How am I suppose to use this?
Post by wmayer »
Select the object in the Tree view and then in the Data tab of the Property Editor you get a "Font" item which you can click on.
