Fasteners workbench based on screw-maker
microelly2
Re: Fasteners workbench based on screw-maker
Post by microelly2 »
To avoid name conflicts I have added subdirs to my workbenches
For example the reconstruction workbench .../Mod/reconstruction has some subdirs
This is the way to load the icons and the scripts
	__dir__ = os.path.dirname(os.path.dirname(__file__))
	def getIcon(self):
		return  __dir__+ '/icons/'+self.Object.mode+'.svg'
import reconstruction
import reconstruction.miki as miki
import reconstruction.tools as tools
import reconstruction.configuration as config
So I can distinguish between geodat.tools and reconstruction.tools.
lukasubo
Post by lukasubo »
Nice workbench, fasteners are always such a pain in the ass. I'm currently being made to manually draw retaining rings instead of just using the STEP files on the Spaenaur website, as a learning experience for a drafting class, but I doubt I want to be doing that for every fastener I ever use. :P
However, I'm curious. Why GPLv2? It'll never be mainlined in FreeCAD unless it's LGPL2+, right? Not necessarily a criticism, it just seems common in many FreeCAD add-ons.
shaise
Post by shaise »
lukasubo wrote: However, I'm curious. Why GPLv2? It'll never be mainlined in FreeCAD unless it's LGPL2+, right? Not necessarily a criticism, it just seems common in many FreeCAD add-ons.
To be frank, I really do not actually understand all the subtleties of all the GPL licenses, Aside from the screw-maker macro itself around which this WB is based (which is not mine, and actually IS under LGPL2) It can be any license you like.
shai
lukasubo
Post by lukasubo »
shai
Actually, depending on how you link to that macro, it may have to also be LGPLv2. Just as a rule of thumb, though, if you want it to have a chance of being included in FreeCAD by default (not sure if it's a goal or if they'd allow it), it should be LGPLv2+ (same licence as FreeCAD).
triplus
Post by triplus »
Probably it makes sense if any mod is reading this to move answers starting from here:
viewtopic.php?f=8&t=11429&start=130#p115171
And are related to Workbench SVG icon support to separate thread.
Thanks.
Renderbrandt
Post by Renderbrandt »
Any plans on including imperial (ansi) threads?
Renderbrandt
In the mean time, you can get all kinds of fasteners (and other things) in STEP format (& others) at http://www.mcmaster.com
I use it all the time.
pperrin
Post by pperrin »
Still loving the workbench...
What I'd really like added is a 'threaded rod' to go with the 'tap thread', and a parameter for tolerance.
I may have a look at the code to see if I can add these to mine - I am a programmer, but python isn't my thing (yet :) )...
Ruanova
Post by Ruanova »
Hi, I love this macro, but I use FreeCAD v0.18
Is it possible to make it work in this version of FreeCAD?
Thank you.
shaise
Post by shaise »
the workbench works on ver 0.18.
use the addon manager, and install "fasteners" workbench
