I am able to complete items to my liking, however, on re-opening, the items look like in my screen shot- Weird and drawings missing.
I am wondering if OpenGL is too old, or OpenGL settings aren't correct- I really don't understand terms intel provides.
Thanks for the program.
Drawings Missing on Re-Open- OpenGL Settings?
- 42mm Hex 01 In.FCStd
- (84.83 KiB) Downloaded 31 times
- 20150703 OpenGL.jpg (66.29 KiB) Viewed 800 times
Re: Drawings Missing on Re-Open- OpenGL Settings?
Could a moderator please move this to the Help on using FreeCAD subforum please
uptownsport,
Please post your FreeCAD information (Instructions are on the link in my signature). What you are experiencing is a fork on your model history. In simple words, instead of working on a single piece, you created several pieces occupying the same space. Later I'll try to post your file with a correct model history and a comparison with your original file.
uptownsport,
Model is not forked, he just has the "Bore 46mm" feature visible as well as "2d 19mm brg bore001". All that needs done is to toggle "Bore 46mm" hidden like it is supposed to be normally and everything will look correct. The dep-graph looks just as it should for that part.
As for the Drawing not showing up, did you save it after you made the drawing?
Mark
Mark
Hmm, guess I still can't eyeball problems .
Currently I'm away from my computer so I can't check the file, and the tree view gave the impression of a forked model.
My apologies.
My apologies.
And so it does!quick61 wrote: All that needs done is to toggle "Bore 46mm" hidden like it is supposed to be normally and everything will look correct.
... that bearing bore is what I was referring to as a drawing, so it all shows now.As for the Drawing not showing up, did you save it after you made the drawing?
Thank you, sir Mark!
Your welcome, and for future reference, questions and problems like this will find a better home and quicker answers when posted in the Help section of the forum.
Mark
Mark
