triplus wrote:What is the procedure on openSUSE to get up to date development release of FreeCAD? Did you compile it? Or installed from somewhere?
Just install last release from Packman repository. I has try install other version from other repository, but same result... On other system this versions works fine (on other more old version of system).
Yes i have a feeling this is issue related to:
After system update
From older version of openSUSE to Tumbleweed? What i would do first is to try it out on fresh openSUSE Tumbleweed installation. For example by using VirtualBox. If it would work probably something went wrong with OS upgrading. If it would not work you could try to compile FreeCAD manually as probably there is something wrong with the package you installed.
Phazeus wrote:On other Tumbleweed (similar OS version) all works fine. The problem in my own installation only
Yes. What you could try is to remove FreeCAD completely (plus the .cfg files) and try to install it again. If that won't work i am afraid your OS upgrade phase didn't go as planed and that will need to get fixed first.
Problem was solved with deleting ".profile" file from home directory with next content:
export LANG=ru_RU.UTF-8
export LC_ALL=ru_RU.UTF-8
After deleting this file all works fine
Phazeus wrote:Problem was solved with deleting ".profile" file from home directory with next content:
Thanks for reporting it. Can you reproduce it? To add back the changes you deleted and for FreeCAD to start having the issue again? If yes that would make a nice bug report on issue tracker.
Yes, when I creates this file again, FreeCAD don't loading project again.
Thanks for confirming and i see issue report was already raised. Hopefully solution will be found soon. Until then indeed it makes sense to leave the file intact and to start FreeCAD in a way Werner suggested.
