rockn wrote:I don't know how often you use FreeCAD, but the actual change made a lot of change from a user point of view. (And without improvement).
I agree on this up to a point.
The change Werner introduced is basically still aligned with current axonometric icon in view toolbar. The issue is other 6 view icons on view toolbar are currently biased to one specific axonometric view. Lets say half of the world is accustomed to that axonometric view when doing drawings and the other half of the world is accustomed to different axonometric view perception when doing drawings.
You say that is not important:
Can I repeat we are talking about technical drawing stuff and want to apply it on an arbitrary 3D scene ?
And the actual drawing workbench don't care about the current 3d view.
As we are talking about 3D View and not drawing views. Are you sure it is not important and confusing to follow one accustomization when modelling in 3D View and after switching to another accustomization when doing drawings? Imagine you would need to use inches as a unit in 3D View and after when doing drawings you would use millimetres.
Make it as an option.
What would that option do? Would it be in preferences? Will documentation have 2 icons for the same view? Will there be 2 documentations?
Why if the solution is quite simple? Provide 2 predefined axonometric views (SE, SW) by default and reduce the bias in other 6 view icons. By doing that the problem is solved or am i missing something?
Providing NW and NE axonometric views therefore isn't strictly needed. I just find them convenient. Maybe we could add them but not by default on view toolbar. Therefore user can make custom toolbar with all 4 axonometric views on it without writing any macros before!
I saw the mase branch to start changing at least the position of the icon to match the new standard 3D view, but it still some change to do. For example, the sketcher creation.
If you are talking about the dialogue only swapping current icons with new icons for view toolbar would be needed. No code change there and no duplication of work with the view icons needed.
And what is the improvement of this ?
FreeCAD not lacking anymore in this area as it does now.
Same, please, let the default setting as it was before...
What about the other half of the world?
P.S. Anyway as for the icon suggestions that is still opened. This week i will invest some time in making another sample toolbar based on the feedback given. If somebody else doesn't step in before me doing that...
