Why Coin3D and not OpenSceneGraph
Hello all!
Coin3D is a death project. No docs, no maintainers.
OSG is under LGPL. New versions are released. There are documentation and books.
Re: Why Coin3D and not OpenSceneGraph
When FreeCAD started around 15 years ago Coin3D was well supported. And OpenInventor at this time already was a mature system and well-known. About OpenSceneGraph I don't know how usable it was at this time since it was a very young project there.Coin3D is a death project. No docs, no maintainers.
And that there are no docs is wrong. There is an on-line documentation and there are the books Inventor Toolmaker and Inventor Mentor which gives many great tips how to extend the library with user-defined classes.
Besides this what are the big advantages of OpenSceneGraph over Coin3D?
I look from present situation, but you are right. The best is the enemy of the good.
- tanderson69
openscenegraph and its kdtree implementation are giving me better selection performance over coin3d. Here are some videos with side by side windows of freecad and an openscenegraph selection window. This isn't a very rigorous comparison, but I think the video shows better performance.wmayer wrote:Besides this what are the big advantages of OpenSceneGraph over Coin3D?
https://www.datafilehost.com/d/0353807c
https://www.datafilehost.com/d/9089fd79
https://www.datafilehost.com/d/c094f0b0
Openscenegraph is a more modern c++ api and isn't held together by dozens of obscure macros like coin3d. Keep in mind I am not suggesting freecad or anybody change, just relaying my personal experience.
interesting tests! Indeed the freecad window is more or less what I have too with large models. But is it the fault of Coin? Or is it the way we use it?
in any case it is true that coin is progressively being abandoned (we must be the biggest opensource project that uses it today) and that openscenegraph is increasingly used everywhere, even for games (openMW and Flightgear).
at some point in time it could be interesting to have a deeper look at it, what would it imply to switch, etc. It's certainly no small task, but we're switching so many things recently, we're getting good at it, no?
That would be the most challenging change. I imagine it would be roughly the same amount of work as the Qt3-to-Qt4 port which took us more than 2 years. However, for the Qt4 port we could use the Qt3 support library so that it was possible to do the movement step-by-step but with replacing Coin3d such a smooth movement isn't possible.at some point in time it could be interesting to have a deeper look at it, what would it imply to switch, etc. It's certainly no small task, but we're switching so many things recently, we're getting good at it, no?
And when thinking about a change to another rendering library we should think about which one to use. At the moment I see three candidates:
- OpenSceneGraph: like Coin3d this a scene-graph library and I would imagine that many concepts are similar so that it probably won't cause a complete redesign of our view providers
- VTK: is the de-facto standard for complex FEM renderings and since it's already used in the FEM module one could also think about using it everywhere in FreeCAD. However, this is not a scene-graph based library and would cause a redesign of the view providers, I guess.
But of course it's still possible to use two rendering systems. - Qt 3D: is rather new and if am not totally wrong it's not a scene-graph based system, either. The benefit is that it's part of Qt and many thing will work out of the box.
Maybe some stuff could be done step-by-step, for ex. building a kind of abstraction layer that the view providers would use?
Anyway, you are right of course, this is not something to be undertaken tomorrow. Specially because at the moment, there is no problem with coin at all. But who knows in the future, it's always good to keep an eye on alternatives...
As an end user, I'm mostly interested in the way models are displayed. FreeCAD is currently lacking in the way it can for example represent shapes in wireframe mode. Hidden and visible edges are displayed the same, when it should be possible to set hidden edges to either dotted lines or dimmed lines (my personal preference). Would switching to a different rendering library make it easier, or is it irrelevant?
According to discussion about WebGL support (viewtopic.php?f=10&t=2397) it seems to be good idea to implement visualization under OpenSceneGraph.
It will be easy to implement WebGL via OSG.js (same data structures as OpenSceneGraph).
What can be started creation by the abstraction vizualisation layer? How interfaces can be extracted? Or is this issue can be resolve only by founding fathers of FreeCAD?
The things to do are rather easy (well, at least doable but we won't scare anyone ) and could be done by anybody with a good c++/python/freecad knowledge. It just is a tremendous amount of work involved to get this going. And I mean really a lot! If you think the benefits outweight the work needed you could start imediatelynazal wrote:What can be started creation by the abstraction vizualisation layer? How interfaces can be extracted? Or is this issue can be resolve only by founding fathers of FreeCAD?
