bernd
Posts: 12851 Joined: Sun Sep 08, 2013 8:07 pm
Post
by bernd » Thu Mar 23, 2017 9:34 pm
DeepSOIC wrote: bernd wrote: Is there a way to get a non-manifold shell with OCCT 7.0 or 7.1 ?
Via python I think it can be created. I think if you run faces through BooleanFragments first, then re-pack them into a shell using
Part.Shell(compound_of_faces.Faces) , it will create a non-manifold shell. I don't think it is doable with gui only, so far.
Part.show(Part.Shell(App.ActiveDocument.Fusion.Shape.Faces))
bernd
Post
by bernd » Fri Mar 24, 2017 6:13 am
I tried to do the same for getting a huge wire. The aim is a wire which has all edges connected. Attached the file and the command. I got an error ...
Part.show(Part.Wire(App.ActiveDocument.BooleanFragments.Shape.Edges))
Part.OCCError: BRep_API: command not done
DeepSOIC
Posts: 7896 Joined: Fri Aug 29, 2014 12:45 am
Post
by DeepSOIC » Fri Mar 24, 2017 11:41 am
Wires are quite a bit more troublesome, because order is important. I'm not sure if non-manifold wires are supported by OCC in general...
