The Big TechDraw Comments Thread
Re: The Big TechDraw Comments Thread
Scale in hatch is changes, Freecad hang 2-3 minutes. Example If I want to change to 100. But it will change to 1, 10, 100. So Freecad hangs 2-3 minutes to change scale. It is nice change to expression like on OK or enter Value accepted.
In property Side bar list, Hatch pattern is a value. If it is a list like first hatch wizard, It will be very nice. On fly I can change. Now I need to delete & redo pattern to change hatch pattern.
I used below honey pattern, But it is showing as diamond.
*HONEY, Honeycomb pattern
0, 0,0, .1875,.108253175, .125,-.25
120, 0,0, .1875,.108253175, .125,-.25
60, 0,0, .1875,.108253175, -.25,.125
- wandererfan
I'd like this too, but I don't know how to make the property editor only respond on "Enter" yet. If you have a pattern with a line every mm on a big face, it's going to be slow.jaisejames wrote:Scale in hatch is changes, Freecad hang 2-3 minutes. Example If I want to change to 100. But it will change to 1, 10, 100. So Freecad hangs 2-3 minutes to change scale. It is nice change to expression like on OK or enter Value accepted.
If you type in a valid pattern name, it should redraw with the new pattern, no need to delete old hatch. Again, don't know how to get PropertyEditor to display list of pattern names extracted from a file yet.jaisejames wrote: In property Side bar list, Hatch pattern is a value. If it is a list like first hatch wizard, It will be very nice. On fly I can change. Now I need to delete & redo pattern to change hatch pattern.
OK, will check it out. Delta-X isn't implemented yet, and dash-pattern is still suspect. That might be why it doesn't look right.jaisejames wrote: I used below honey pattern, But it is showing as diamond.
Thanks for testing.
wf
Don't know the tech draw code, but normall behaviour is that the property editor changes the property at each change. However, features should not react on that. The onChanged functions should normally not implement feature update logic, only if it is very fast. This is to prevent exactly the observed behaviour. The feature should only recompute its output in the recompute function. This is called when someone hits enter in the property editor or finish's the editing by leaving the input field.. I'd like this too, but I don't know how to make the property editor only respond on "Enter" yet. If you have a pattern with a line every mm on a big face, it's going to be slow.
I don't seem to be able to turn view frames off for an imported svg symbol. User error?
Version: 0.17.10001 (Git)
Hash: 095d462cba9af1945c4d2163beb739c366a4b234
Python version: 2.7.8
OCC version: 7.0.0
OS: Windows 7Word size of OS: 64-bit
OCC version: 7.0.0
"fight the good fight"
Nope, same problem here. If you create a view of the Cube, then the "Turn View Frames on or off" button becomes active.
OS: Ubuntu 14.04.5 LTS
Version: 0.17.10000 (Git)
Build type: None
Hash: 216d8c66dcc2ed92546e73b242e2123bda2b038e
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Build type: None
Qt version: 4.8.6
Thanks for checking.NormandC wrote:Nope, same problem here. If you create a view of the Cube, then the "Turn View Frames on or off" button becomes active
Hi. Are there any ways to use or plans to implement broken section views? Or at least one not aligned with the origin planes?
Case in point, /r/cad challenge 15 moderate
- wandererfan
Nope. Programmer error. Thank you. issue #2889sgrogan wrote:I don't seem to be able to turn view frames off for an imported svg symbol. User error?
[quote="wandererfan"][/quote] Can I ask for small update? Is it possible to know when approx. will be circle on detail view?
Some other questions:
1) Are you planning some kind of sketch on drawing - where could be possible to add new lines, boxes, etc. Would be nice to may a draw a circle on drawing, point it and then choose detail - probably it is far way right now.
2) Are you planning method of changing models connected to the drawing. Hard to explain, but I'll try: I have for example box1 and I am performing drawing for it and save it. Then I take box1 and resave it as a box2 and this time I don't wan't to make a new drawing, but I resave drawing box1 into box2 and link it to the box2 file. Then open box2 file and all dimensions are fit to new dimensions of box. This simple way I save a lot of time to creating new drawing, which is refered to the same (but with changed dimensions) and I have two separated drawings.
Is there way to help you by non-programmer?
- wandererfan
1) Yes. https://www.freecadweb.org/wiki/index.p ... awingTools. I did have a proof of concept at one time, but it is horribly out of date now. The real difficulty comes in keeping the sketch bits attached to the drawing bits. Currently leaning towards a transparent layer on top with no actual linkage to the underlying drawing. No ETA at this time.efyx wrote:Can I ask for small update? Is it possible to know when approx. will be circle on detail view?wandererfan wrote:
2) Not sure I follow this one. If you make a drawing in box1.fcstd, then SaveAs box2.fcstd, box2.fcstd will contain a copy of the drawing. If you then change dimensions in box2.fcstd, they will propagate to the drawing page as usual (subject to the usual "topological naming" issues) and you will have 2 drawings, 1 in each file. But I think I haven't understood.
As for the detail highlight circle, it just keeps getting bumped by other stuff.
As for help from non-programmer, the wiki pages are weak and I haven't done anything in the way of a tutorial yet. That would help. Testing/bug reporting is always appreciated too.
wf
