Having Draft workbench set as default start-up workbench
Changing Draft interface mode from default Taskview to Toolbar
When FreeCAD is started strange things start to happen.
Will look into it over the weekend. For now you can avoid the issue by not using TabBar or not having Draft workbench set as default start-up workbench or by not setting Draft interface mode to Toolbar mode.
Thanks for discovering this and reporting it. It is hard to test all possible combinations and here FreeCAD (TabBar) users can provide valuable feedback.
mario52 wrote:hi
one little bug discovery
triplus wrote:Changing Draft interface mode from default Taskview to Toolbar
i work with this method (Taskview) and all work fine
haa l'informatique !
thanks
mario
I took a quick look yesterday and it seems using a timer to trigger TabBar on start is clashing with Draft start process. I can't be 100% sure on why as i likely won't investigate this further but in DraftGui code some timers and some special dock widget creation code is used. If i remove timer to trigger TabBar on start the problem seems to go away. Therefore i will try to change the way TabBar is started and that should allow you to use TabBar + Draft/Arch workbench set as start-up module + having Draft interface mode changed from default Taskview to Toolbar. I can't do it over the weekend as other work emerged. Hopefully this will be sorted out around next weekend. Will report here once that happens.
Yes that is why it will take some time as simply removing timer isn't enough. I will have to slightly change other sections in the code to adapt them to this new condition. And after that some testing will need to be done... Therefore realistically i won't have the time to do it this weekend.
P.S. Creating dock widgets (DraftGui) from Python early in the start-up process and iterating over them from TabBar don't play along nicely. Therefore i changed the TabBar logic to be more explicit when finding TabBar related dock widget and that hopefully fixed the problem you were experiencing.
