One the FC wiki debugging page it says: (emphasis mine)
So where are these pre-compiled debug versions? Searching for them doesn't yield clear results.If you are running a version of FreeCAD from the bleeding edge of the development curve, it may "crash". You can help solve such problems by providing the developers with a "backtrace". To do this, you need to be running a "debug build" of the software. "Debug build" is a parameter that is set at compile time, so you'll either need to compile FreeCAD yourself, or obtain a pre-compiled "debug" version.
So my question is what is the status of said debug builds? Will we have them available? If so, lets link to them from pages like 'Debugging' on the wiki.
Also in the meantime, I propose adding links to the debugging page on how to compile FC per ones platform/distro *which already exist. Is that cool?
