It seems that TechDraw::DrawProjGroup secondary views works in mirrored axes when compared to Drawing::FeaturePage secondary views.
Is that intentional? The tooltip says Right and view label says Left.
I am using
OS: Mac OS X
Version: 0.17.9940 (Git)
Branch: (detached from 1afa150)
Hash: 1afa150585c7137447e490c8ca5e94ea1258a1ba
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 7.0.0
See attached screenshot.
TechDraw::DrawProjGroup secondary view works in opposite directions
- Screenshot 2017-02-03 00.20.49.png (931.42 KiB) Viewed 809 times
- wandererfan
Re: TechDraw::DrawProjGroup secondary view works in opposite directions
Are projection angle and view direction set the same in both? Looks like First Angle in your picture with View direction (0,-1,0).sirkkalap wrote:It seems that TechDraw::DrawProjGroup secondary views works in mirrored axes when compared to Drawing::FeaturePage secondary views.
The checkboxes (and tooltips) refer to which "slot" on the page is going to be filled with a view. The tooltips could be changed to reference the 3d model and reverse Left/Right and Top/Bottom if First Angle is selected, if the current arrange is too big a problem.sirkkalap wrote: Is that intentional? The tooltip says Right and view label says Left.
Right you are. I was confused. Thanks.
