App::FeaturePython discussion
jacknotreally
Post by jacknotreally »
after working a while with "App::FeaturePython" i found it would be helpful
to have a feature derived from "Part::Feature".
The "App::FeaturePython" as now, has no automatic representation of itself like a "Part::Feature".
I would prefer a "App::FeaturePython" with a default viewprovider like that in "Part::Feature" and a default Shape-Property that´s
represent its geometry (and being visible at default).
That would help in dealing with Shape-constructions that don´t use any special coin objetcs.
Jack - not really
Founder
Re: App::FeaturePython discussion
Post by wmayer »
Yes, this makes much sense. I have it already on my todo list for some time but until now didn't find the latter to implement it. I have submitted an issue on the Mantis tracker to myself (https://sourceforge.net/apps/mantisbt/f ... .php?id=41)
Founder
Post by wmayer »
I have added the new class Part::FeaturePython which inherits from App::FeaturePython and has its own shape property. The associated view provider class does the update of the view representation so that inside your Python code you don't have to worry about this anymore.
Here a fully working example:
import FreeCAD, FreeCADGui, Part
from pivy import coin
class PartFeature:
	def __init__(self, obj):
		obj.Proxy = self
class Box(PartFeature):
		PartFeature.__init__(self, obj)
		''' Add some custom properties to our box feature '''
		obj.addProperty("App::PropertyLength","Length","Box","Length of the box").Length=1.0
		obj.addProperty("App::PropertyLength","Width","Box","Width of the box").Width=1.0
		obj.addProperty("App::PropertyLength","Height","Box", "Height of the box").Height=1.0
	def onChanged(self, fp, prop):
		''' Print the name of the property that has changed '''
		FreeCAD.Console.PrintMessage("Change property: " + str(prop) + "\n")
		if prop == "Length" or prop == "Width" or prop == "Height":
			fp.Shape = Part.makeBox(fp.Length,fp.Width,fp.Height)
	def execute(self, fp):
		''' Print a short message when doing a recomputation, this method is mandatory '''
		FreeCAD.Console.PrintMessage("Recompute Python Box feature\n")
class ViewProviderBox:
		''' Set this object to the proxy object of the actual view provider '''
		obj.Proxy = self
	def attach(self, obj):
		''' Setup the scene sub-graph of the view provider, this method is mandatory '''
		return
	def updateData(self, fp, prop):
		''' If a property of the handled feature has changed we have the chance to handle this here '''
		return
	def getDisplayModes(self,obj):
		''' Return a list of display modes. '''
		modes=[]
		return modes
	def getDefaultDisplayMode(self):
		''' Return the name of the default display mode. It must be defined in getDisplayModes. '''
		return "Shaded"
	def setDisplayMode(self,mode):
		''' Map the display mode defined in attach with those defined in getDisplayModes.
		Since they have the same names nothing needs to be done. This method is optinal.
		return mode
	def onChanged(self, vp, prop):
	def getIcon(self):
		''' Return the icon in XMP format which will appear in the tree view. This method is optional
		and if not defined a default icon is shown.
		return """
			/* XPM */
			static const char * ViewProviderBox_xpm[] = {
			"16 16 6 1",
			" 	c None",
			".	c #141010",
			"+	c #615BD2",
			"@	c #C39D55",
			"#	c #000000",
			"$	c #57C355",
	def __getstate__(self):
		''' When saving the document this object gets stored using Python's cPickle module.
		Since we have some un-pickable here -- the Coin stuff -- we must define this method
		to return a tuple of all pickable objects or None.
		return None
	def __setstate__(self,state):
		''' When restoring the pickled object from document we have the chance to set some
		internals here. Since no data were pickled nothing needs to be done here.
		return None
def makeBox():
	FreeCAD.newDocument()
	a=FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Box")
	Box(a)
	ViewProviderBox(a.ViewObject)
