Better name and already available, I should have guessedDeepSOIC wrote:BTW! Macro Align View to Face
FC0.17 usage details
Re: FC0.17 usage details
Linking issue #3007 to this thread
Curved faces is more complicated since the face and one point of the surface are needed, because every normal vector of the surface is unique and it's needed calculate the tangent plane of the surface in every point. For flat faces, all normal vectors are equal and the tangent plane is the same that the flat face. See https://en.wikipedia.org/wiki/Normal_(geometry)cox wrote:Could this be called "View face from normal", it might work on curved faces as well.raulshc wrote: What is your opinion?
Would also be nice in arch and eventually Assembly to have the reverse direction "View from face normal" ?
That is the desired behavior, but integrated with C ++ code as in the other cases. I have tried it and it works very well.DeepSOIC wrote:BTW! Macro Align View to Face
Werner fixed this issue. See git commit 8f5057araulshc wrote:*The Sketcher symbol isn't displayed in the preferences editor. This happens in 0.17.10802 x32 version under windows 7 32bit.
@raulsc please bidirectionally link ticket <=> thread. I did it for you previously:raulshc wrote:...
Kunda1 wrote:Linking issue #3007 to this thread
Since you now opened another ticket: issue #3011 to this thread. It helps with bug triaging and cut down on bug tracker bloat. Thx.
OK, no problemKunda1 wrote:@raulsc please bidirectionally link ticket <=> thread. I did it for you previously:raulshc wrote:...
Hi to all,
other question, in relation to Sketcher; in the constraints system, I have noticed that there are not two geometric restictions that other parametric modellers have; the Concentricity constraint and the Midpoint constraint. I have also noticed that there are created icons that symbolize these restrictions on the Arkwork page of our wiki.
Any plan to implement these restrictions on the sketcher coming soon?
- DeepSOIC
We already have them. Concentricity is simply making center points coincident, and midpoint is represented by symmectric (select point and line and click symmetric constraint). So adding them as separate constraints won't do much apart from taking up toolbar space.raulshc wrote:other parametric modellers have; the Concentricity constraint and the Midpoint constraint
I know, it's just about usability improvement issues. From the programmer's point of view, the resolution algorithm has to be optimal, and these constraints are redundant. From the point of view of the user and his experience in design, having a restriction that can do the same by using two edges (for example, two circle arcs for concentricity) than two matching center points can facilitate the work of the designer and reduce the times of design.
When the main parametric 3D modelers (CATIA, Solidwoks, Creo, ect.) Have it, even though it is redundant, it is for some reason related to what I said, I think.
