Bugtracker recent changes
Re: Bugtracker recent changes
The whole Arch subproject has also disappeared with apparently all its issues.
We should urgently resore a backup. Since people are still adding to the tracker, I've set it offline now.
Kurt, do you have a backup available?
- DeepSOIC
MantisBT wrote:MantisBT
The FreeCAD bug tracker is currently offline for maintenance scheduled on january 18, 2017
- kkremitzki
Yes, I have one from a couple of weeks ago. I will go about restoring from it ASAP.yorik wrote:The whole Arch subproject has also disappeared with apparently all its issues.
Sorry for the lack of updates on this--I had a chance to look into manual restoration of the issues over the weekend. It turns out MantisBT has both CSV/XML export and import of issues, but the CSV import doesn't work with Mantis 2.x, and the XML import relies on a PHP XML module being present, which is apparently not the case on the shared host.
Forgot to change the message... Shoudl be better now.DeepSOIC wrote:The FreeCAD bug tracker is currently offline for maintenance scheduled on january 18, 2017
- kkremitzki
The tracker is up again.
I restored from the last backup, done 3/29. I took another backup before restoring so that there'd be a snapshot of the issues added since, but because the event happened on Apr 17 there's possibly some stuff that was never backed up between 3/30 and 4/17.
Two weeks from now and I'll be done with finals which should give me some time to make a more permanent weekly/monthly backup system using cron on the project servers, and hopefully the pain of this issue will never have to be felt again.
- DeepSOIC
Thanks Kurt!!
- kkremitzki
The backup I grabbed today of the tracker is live in my staging environment and can be browsed (for the time being) if anyone wants to see stuff in the 3/29-4/25 window:
https://freecad.io/tracker/my_view_page.php
thanks for all the work! FYI the URL is unreachable.kkremitzki wrote:The backup I grabbed today of the tracker is live in my staging environment and can be browsed (for the time being) if anyone wants to see stuff in the 3/29-4/25 window:
PS hope finals went well for you
Missing fixed tickets and their counterpart commits for quick reference:
issue #2998 <= git commit c902422f635 & git commit d8b8bbda312ac
issue #3003 <= git commit fcd459e6e3be
issue #3009 <= git commit 4c3ffb57ca9b
Existing tickets but missing commit attachments (these mantis bugs have been notated)
issue #1999 <= git commit a289538e034 & git commit add9bf910b
issue #2810
issue #2986
issue #2978
issue #2994
issue #2937 <= git commit 886ba74bfd0
General info:
Missing tickets start at issue #2998 and end at I'm guessing issue #3013(?)
Todo: reference bugtracker emails to learn about other BT activity
Edit: this is a live post that will be updated often
issue #2810
issue #2986
issue #2978
issue #2994
General info:
Should this be stated on the mantis website, so reporters can look up what is missing and report again.
BR, Howil
BR, Howil
