why opencascade' speed to read stl file not as fast as freecad
451813447@qq.com
Post by 451813447@qq.com »
In my application now I use freecadcmd to read the stl 's width、height、volume and area, and the code is bellow:
import sys, Mesh, string, json,os
from FreeCAD import Base
filename = sys.argv[2]
name_arr = filename.split('.')
mesh = Mesh.Mesh(filename)
obj["area"] = mesh.Area
obj["volume"] = mesh.Volume
as it as ap.py and call it by : freecadcmd ab.py xxxx.stl
But now I want to use occ , and the c++ code is bellow:
int main(int argc, char *argv[]){
    if(argc <= 1){
        std::cout<<"occstl wrong arguments count!"<<std::endl;
        return -1;
    Standard_CString aFileName = argv[1];
    TopoDS_Shape shape;
    StlAPI_Reader reader;
    reader.Read(shape,aFileName);
    GProp_GProps system;
    BRepGProp::VolumeProperties(shape, system);
    Standard_Real volume = system.Mass();
    std::cout<<"volume:"<<std::to_string(volume)<<std::endl;
    BRepGProp::SurfaceProperties(shape, system);
    Standard_Real area = system.Mass();
    std::cout<<"Area:"<<std::to_string(area)<<std::endl;
Then I use the same stl file , the app use freecadcmd cost three second, but the occ c++ code cost about 2 minutes.
Forgive me but I don't use c++ very well , can anyone explain why the difference of speed is so big?
ickby
Re: why opencascade' speed to read stl file not as fast as freecad
Post by ickby »
FreeCAD does not use OCC for mesh handling but has its own mesh data structure. Hence you compare two totally different implementations.
Founder
Post by wmayer »
This does much more than just reading in the data. It also converts the mesh into a topo shape which is a very expensive operation. You can compare with the function "Create shape from mesh" in the Part workbench.
451813447@qq.com
Thinks you two , very very much !
