BOLTS Open Library of Technical Specifications
Re: BOLTS Open Library of Technical Specifications
I managed to fix 5), and add 6) in the latest development snapshot.
7) is probably related to the model file, as at least on my system the profiles with one, two and three slots do not cause this message.
Hi
Don't know if this is the right place for this.
I would like to use BOLTS for FreeCAD on windows. when I try to run start_bolts.FCMacro from the macro menu I get the following error
I am running FreeCAD0.13 (32 bit) on windows 7 64
OS: Windows 7
Platform: 32-bit
Version: 0.13.1828
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.3.0
Thanks for your help
Steve
File "C:/Users/steve/FreeCad_macro/start_bolts.FCMacro", line 1, in <module>
import BOLTS
File "C:/Users/steve/FreeCad_macro\BOLTS\__init__.py", line 20, in <module>
from bolttools import blt_parser
<type 'exceptions.SyntaxError'>: ('invalid syntax', ('C:/Users/steve/FreeCad_macro\\BOLTS\\bolttools\\blt_parser.py', 72, 34, '\t\tself.standardized = {body:[] for body in self.standard_bodies}\n'))
OS: Windows 7
Platform: 32-bit
Version: 0.13.1828
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.3.0
Steve
Yes, this is the right place.
We discovered this problem a while ago, but unfortunately after the 0.2 release. I was not aware that certain Python constructs that I used in the BOLTS code were added only only in Python 2.7. If you try to run BOLTS with Python 2.6, then it complains about these parts of the code.
I changed all these parts, so the latest development snapshot should work:
http://jreinhardt.github.io/BOLTS/downl ... 9_gpl3.zip
You also need to install importlib, a module that was added to the python standard library only in 2.7, so users of older versions miss it:
https://pypi.python.org/pypi/importlib/1.0.2
instructions on how to install python modules in windows can be found here:
http://docs.python.org/2/install/index.html
Thanks for the reply
I now get the following error when trying to run bolts
I have installed both PyYAML-3.10 and importlib-1.0.2 and am trying to run the BOLTS_FreeCAD_201311211229_gpl3 snapshot
Thanks again for your help so far
Steve
OS: Windows 7
Platform: 32-bit
Version: 0.13.1828
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.3.0
import BOLTS
File "C:/Users/steve/FreeCad_macro\BOLTS\__init__.py", line 24, in <module>
from freecad.gui.freecad_bolts import BoltsWidget, getMainWindow
File "C:/Users/steve/FreeCad_macro\BOLTS\freecad\gui\freecad_bolts.py", line 18, in <module>
from PyQt4 import QtGui, QtCore, uic
File "C:\Program Files (x86)\FreeCAD0.13\bin\PyQt4\uic\__init__.py", line 3, in <module>
from PyQt4.uic.Compiler import indenter, compiler
File "C:\Program Files (x86)\FreeCAD0.13\bin\PyQt4\uic\Compiler\compiler.py", line 3, in <module>
from PyQt4.uic.properties import Properties
File "C:\Program Files (x86)\FreeCAD0.13\bin\PyQt4\uic\properties.py", line 5, in <module>
from PyQt4.uic.icon_cache import IconCache
<type 'exceptions.ImportError'>: No module named icon_cache
Steve
OS: Windows 7
Platform: 32-bit
Version: 0.13.1828
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.3.0
Ok, there seems to be a problem with the Qt version provided by the FreeCAD stable release for Windows. The same problem is discussed here:
viewtopic.php?f=22&t=981&start=10
No solution yet, but I will try to work around this problem, as apparently many people are stuck with rather old versions of Qt.
Ok, I just uploaded a new development snapshot:
http://jreinhardt.github.io/BOLTS/downloads.html
I tried to work around the issue, could you please test this. You should not need to install anything apart from yaml and importlib, which you have already done. Thanks
Thank You this has solved the problem.
Do you have plans to incorporate machine screws and other parts, if so this site has a lot of dimensional data
http://www.trfastenings.com/pages/Metri ... ine+Screws
Steve
Steve
Glad to hear that it works now.
Thank you for the link, I put it to my notes. It is not so difficult to add new parts to BOLTS, you can try to add them yourselves, if you want (or somebody else). Two things are necessary:
The dimension data (for example from a site like the one you linked) and some metadata has to be entered into a plain text file in a certain way. I wrote a bit about that here:
http://jreinhardt.github.io/BOLTS/doc/g ... files.html
But probably it is easier to look at the blt files for the other parts, and follow the structure
https://github.com/jreinhardt/BOLTS/tree/master/data
And a geometry for the part has to be created. This can either be a python function that creates the part for a certain combination of parameters, or a FreeCAD model file (fcstd) that is parametric. Usually the python function is easier. I also wrote instructions on that (FreeCAD Contributor Documentation):
http://jreinhardt.github.io/BOLTS/doc/index.html
I am happy about all kinds of contributions, and will gladly assist with all problems that come up.
Greetings
Greetings
Hi again,
development of BOLTS has not stopped, i just did not write so much about it. And most of the things I did was behind-the scenes stuff or work on other backends. But in the future I want to focus more on adding parts, to make BOLTS more useful.
I just uploaded a new development snapshot of BOLTS for FreeCAD that contains V-Slot profiles from OpenBuilds part store and a corresponding Double V Wheel.
The models were kindly provided by quick61. He drew the profiles as faces. I converted the faces to sketches using the FaceToSketch macro and the EdgesToArc macro that I hacked together for this purpose. BOLTS can currently not handle extrusions from faces, only padded sketches. I converted the faces to sketches with some help from here.
Including a part that is already available as a fcstd model (with an appropriate license) into BOLTS is usually not difficult, but requires editing of text files and some basic knowledge of git. This is a invitation to you to try to add parts to BOLTS.
BOLTS needs to three things to be able to provide a part in FreeCAD:
First a few general informations about the part, like name, description, available parameters (usually dimensions) and tables. For the OpenBuild parts this information looks like this this.
Second a geometry for FreeCAD. This can either be a python function that can be called with parameter values and creates a new object, or a fcstd file with the model, that is inserted and the parameters (like e.g. the length) adjusted. To have a part available for another supported program, e.g. OpenSCAD, the geometry needs to be provided in a different form, e.g. as a OpenSCAD module, but the general informations are reused.
Third a few informations about the geometry. These go into a different file. For a geometry in form of a fcstd file this includes things like author, license, filenames, names of objects, and what property of which object corresponds to which parameter. For the vrail parts they look like this.
I wrote detailed instructions on how to add python geometries and fcstd geometries, and how to work with blt files (the general informations).
A good starting point is the contribute page, which also has links to other things you can do to help BOLTS, like generating drawings.
All these instructions that I wrote are probably sometimes confusing, I just do not know what technical or conceptual parts are confusing for you. I am grateful for any feedback and will try to improve the documentation and workflow.
Hi jreinhardt ! Very cool , i am looking for openbuilds parts and you added this in BOLT. I will use BOLT more often. Thank you.
