Testing the Drawing Module
Re: Testing the Drawing Module
Hi Luke
I had a go last night and got that crash with axonometric views a few times...I am trying to narrow it down.
The first time I used axonometric views, I thought it was broken because I only got one view auto inserted and no dialogue of any sort, although once you know to double click on it the dialogue then comes up and allows extra views to be inserted. I think it would possibly be more intuitive if the dialogue opened on creation...but I am not sure...I'll try it again
I'll write back later....
Jim
Jim
Sure! Let me know what the crash is. Hopefully it'll be something trivialjmaustpc wrote:I had a go last night and got that crash with axonometric views a few times...I am trying to narrow it down.
Yeah I would want that too, I currently cannot make the task dialog open because of low level functionality. Hopefully that should be resolved soon. Also would people prefer if a top and right view be created by default?jmaustpc wrote:The first time I used axonometric views, I thought it was broken because I only got one view auto inserted and no dialogue of any sort, although once you know to double click on it the dialogue then comes up and allows extra views to be inserted.
That sounds fine. What I can do is check if the geometry is a full circle/hole and it will automatically add the centre lines otherwise you will have to toggle it explicitly via the radius / diameter dimension. For now It'll be built into the dimension, but it should be relatively straightforward to make a separate annotation feature.normandc wrote:I would certainly prefer to have an option for centerlines to be enabled/disabled. When you dimension a hole a centerline is useful, but I never put them on fillets as is does not make much sense IMO and the view gets too "heavy".
Maybe the center mark could be a specific parameter (on/off) of the radius and diameter dimensions?
What I'm proposing are the following features for the ortho views task dialog:normandc wrote:Making j-dowsett's OrthoViews working again would be nice, but I'm not sure what that would entail.
* Scale (Automatic, Document/Page, Custom)
* Third Angle / First angle
* Spacing between views (locked) - not sure if we need this
I cannot easily do 'view from' or 'axis aligned right' because it requires larger changes.
Show hidden is set per view.
3D Views I could potentially add but for now I think is best to keep as separate '3D Views'
Let me know if you think something is missing.
Development blog - http://freecadamusements.blogspot.co.uk/
Hi Luke
In case you want to repeat anything this is my testing procedure step by step
OS: Ubuntu 14.04 LTS
Platform: 64-bit
Version: 0.14.3198 (Git)
Branch: drawing
Hash: 409beaaaef05df1136bd0fb89bdb820c9e1bb30a
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
Test procedure: -
start FreeCAD go to Part wb,
new doc
insert default Part Cube and cylinder
then Drawing wb
click on A3 icon "insert new drawing" which produces Page and template in tree view
now I have to select template, go to its template parameter ...file browser to a specific template ...A4 Landscape works so I select that. Then click on Page size and then either height or width to make the template display (then I found that you could have just hit enter key)
comments
1) could be nice to get a default template rather than just a blank window
2) to get the template to show up you have to either know to click on template parameter and hit enter key or click on Parameter page size then onto any other parameter. These seem to be the only two ways to get it to show up.
3)would be nice if the default location for the above file browser was the correct directory for the templates
Platform: 64-bit
Branch: drawing
Qt version: 4.8.6
OCC version: 6.7.0
Test procedure: -
new doc
then Drawing wb
comments
next I set views and dimension
click first, left most, yellow insert view icon to insert a view of the cube
drag view to convenient location on Drawing, adjust Scale parameter to 5,
comment
now it is very hard to select the edges and then hard to see if they are selected because they are so thin, perhaps a thicker default line width would help? Maybe its a setting somewhere on my system but its really hard to get the mouse exactly on the line in order to select it. It changes from Black to blue when selected but the line being so thin, it is hard to see the colour change
Adjust line width parameter up due to above, from default 0.7 to 2.7.
select top line of square, select horizontal dimension...work well....can drag the dimension around and arrows etc. change as expected. This is actually really cool.
Now using crtl key select left and bottom edges and select angle dimension ...it fails error message is in triplicate
Exception (Wed May 7 04:11:15 2014): Cannot measure the true angle
Select right edge and deliberately do something stupid...select horizontal dimension even though it is a vertical line ...error is in triplicate again and is wrong message
Exception (Wed May 7 04:13:09 2014): Cannot measure the true angle
now do the proper thing and click vertical dimension ......get error again as above
Exception (Wed May 7 04:17:15 2014): Cannot measure the true angle
Now I try the first dimension icon the on an angle one, "lineal" dimension? same error again.\
actually now attempting to put any dimension on the square from the Part Cube fails with the same error message
so I give up on the cube for a bit and go to the cylinder, select insert a view, left yellow icon ....and it fails to insert a cylinder view and out puts this same error message again in triplicate.
save file and close FreeCAD...back in a bit
comment
exactly the same procedure but with a clean new file
this time vertical dimension on right hand edge of cube's square ...works... the text is vertical ...would be nice to be able to rotate it to horizontal for easier reading...would need to be optional display text orientation so both could be used I would think?
the dimension parameter "Rotation" currently does nothing.
now select top edge and horizontal dimension ...works perfectly
now do something stupid again..select bottom horizontal edge and vertical dimension ...it works as I would expect in that it gives you a dimension with a value of "0".
now use cntrl again to select two edges (left and bottom) click on angle dimension ...now I am back again to the error message in triplicate again
Exception (Wed May 7 04:34:39 2014): Cannot measure the true angle
Once again the above error message comes with anything I now try to do.
Jim
Jim
if I open the above file again, that I had saved, and click on Page in the treeview I get an error message
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Cannot measure the true angle
and no Drawing....but at least the error message is not in triplicate ..
I tried the same again and this time tried to insert a diameter on the cylinder's circle top view...diameter does not appear in the drawing...a dimension does appear in the treeview
I got another crash doing the above ..but I have not been able top repeat it..yet.
Noted. Made a check for completely horizontal and vertical lines.jmaustpc wrote:now do something stupid again..select bottom horizontal edge and vertical dimension ...it works as I would expect in that it gives you a dimension with a value of "0".
jmaustpc wrote:the dimension parameter "Rotation" currently does nothing.
and
I was thinking the rotation parameter could be used to toggle this. The GUI would probably only support 90 degree increments.jmaustpc wrote:this time vertical dimension on right hand edge of cube's square ...works... the text is vertical ...would be nice to be able to rotate it to horizontal for easier reading...would need to be optional display text orientation so both could be used I would think?
This is a usage issue. I need to explain why this happens in a video guide.jmaustpc wrote:now use cntrl again to select two edges (left and bottom) click on angle dimension ...now I am back again to the error message in triplicate again
Here's a question for all, what default colours do people want for highlighted and selected? Atleast till we have a preference dialog.jmaustpc wrote:comment
This is the 'paper' size - i.e. it is the unit thickness of a line on paper in mm (or thereabouts). What I can do is have a multiplier. Eventually this will be in a preference dialog.jmaustpc wrote:Adjust line width parameter up due to above, from default 0.7 to 2.7.
I'm working on diameter. I think because this isn't implemented correctly it can cause crashes.jmaustpc wrote:I tried the same again and this time tried to insert a diameter on the cylinder's circle top view...diameter does not appear in the drawing...a dimension does appear in the treeview
Hey Luke,
I just pulled your latest work and tested it. I love what you've done with the diameter dimension, how the single leader changes to straight dim with extension lines when you rotate the text to the horizontal or vertical axes. The automatic center lines for enclosed circles is perfect. I wish the Ø symbol was possible rather than the letter "D" for diameter, I guess it's an encoding issue that may have been solved with a more recent library (Coin?). I'm still on Ubuntu 12.04 so I'm not sure about that.
I got a few crashes, the only thing I get in the terminal is
Or sometimes just "Segmentation error".
I should learn to properly get a backtrace...
I got them doing various things:
About holes/circles, I've noticed two problems:
This is coming along quite nicely! Thanks for your work Luke!
*** Abort *** an exception was raised, but no catch was found.
... The exception is:SIGSEGV 'segmentation violation' detected. Address 80
- double-clicking on the cView container to add more views
- Moving a view on the page
- Changing the scale of the cView container
- Let's say a plate has a hole on the XY plane (top), when creating a front view with hidden edges on, the hidden line on the side of the cylindrical surface seam is not displayed. See attached file.
- There is currently no way to dimension a hole from its center to another point.
Currently the blue is too dark for my eyes. It's OK for edges, but it's really hard to see for points. A lighter color might be more visible: light green, or even red (although for color-blind people that may be a problem). I wonder if you could simply use the same colors as FreeCAD's preselection/selection colors for the general GUI? (Found in Prefs/Display/Colors)mrlukeparry wrote:Here's a question for all, what default colours do people want for highlighted and selected? Atleast till we have a preference dialog.
- test-mrlukeparry-drawing.fcstd
- (29.98 KiB) Downloaded 51 times
Sorry I'd need a bit more specific information to be able to do anything about this.normandc wrote:Or sometimes just "Segmentation error".
Yeah, I'm aware this happens. I'm not sure really what I can do it, so I'll ask a question on the forums.normandc wrote:Dimensions are listed at the bottom of the tree until some edit is made, then they are placed under their parent views. But I guess you already know that.
Again if you could be a bit more specific when this occurs, I can look into this. I haven't had any problems.normandc wrote:Sometimes a newly created dimension does not appear on the page until I edit something else or add another dimension.
I thought about this when doing the diameter dimensions but will need to do some more changes to see if it's easily possible.normandc wrote:There is currently no way to dimension a hole from its center to another point.
Yeah I can confirm this with my own example. I need someone to check if this happens with the previous drawing module. If it does the same, then there isn't much I can do about it because it's the OCC projection algorithm. In general any 'added' tangent edges are a problem and you'll also find that it struggles with fillets on some occasions.normandc wrote:About holes/circles, I've noticed two problems:
Would these work on a white background? I'm abit sceptical but I agree the blue is too dark and my LCD monitor doesn't have good colour reproduction.normandc wrote:Currently the blue is too dark for my eyes. It's OK for edges, but it's really hard to see for points. A lighter color might be more visible: light green, or even red (although for color-blind people that may be a problem). I wonder if you could simply use the same colors as FreeCAD's preselection/selection colors for the general GUI? (Found in Prefs/Display/Colors)
If someone can do a mock in inkscape with a few options and we can maybe judge the best default?
Thanks!normandc wrote:This is coming along quite nicely! Thanks for your work Luke!
