How to draw a mathmatical function?
smilie
Post by smilie »
Dear peoples,
how can i draw a mathematical functions?
I want to draw y=x²/4 and i need to set some drillings depending of this function.
Any ideas?
Founder
Re: How to draw a mathmatical function?
Post by wmayer »
Check out this link. Since arbitrary parametric curves are not supported this solution does an approximation with line segments (simple) or B-spline curves.
viewtopic.php?f=13&t=6226#p50611
shoogen
Post by shoogen »
smilie wrote:I want to draw y=x²/4
Our geometry kernel support parabolas, so there should be no need to use an approximation
http://opencascade.sourcearchive.com/do ... abola.html
the default Parabola seems to have the right scaling and position, but is symetrical to the x-axis.
import FreeCAD
import Part
p=Part.Parabola
#p.Focal=1.0
p.rotate(FreeCAD.Placement(FreeCAD.Vector(),FreeCAD.Rotation(90,0,0)))
But haven't figured out yet, how to add limits.
jmaustpc
Post by jmaustpc »
Hyperbola is there as well.
Founder
Post by wmayer »
The parabolas are handled the geometric way so that converting the algebraic form y=x²/4 is not that easy. Besides that when using a B-Spline curve of degree two then it's not an approximation but 100% exact.
shoogen
Post by shoogen »
Why? I thought that i just need to set XDir to (0,1,0), YDir(1,0,0) and i would change Axis to (0,0,-1) to keep orientation right handed. The focal length (F) defaults to 1.0
The Geom_Parabola parabola is parameterized as follows:
P(U) = O + U*U/(4.*F)*XDir + U*YDir
wmayer wrote:Besides that when using a B-Spline curve of degree two then it's not an approximation but 100% exact.
That is true for parabolas, but not for the hyperbolas jmaustpc mentioned in the meantime. And getting the 100% exact B-Spline representation is not obivous to me. (I wouldn't trust the OCCT interpolation functions on this).
