I strongly disagree.jmaustpc wrote:If that is the case then what we possibly could do then is ONLY link to the 64bit version, then those few left on 32 bit will find it doesn't work, that they have the "wrong" version and hopefully have the brains to go look for the correct version.
First of all, do you have hard numbers on the ratio of 64-Bit VS. 32-Bit home Windows PCs? I couldn't find any survey or study (but I didn't spend more than a few minutes). My feeling is that there are still A LOT of 32-Bit Windows PCs being used. FYI you can purchase low-end laptops right now with Windows 8.1 32-Bit.
Second, how will people react when they download a 146MB installer only to find out it is not compatible with their PC and they have to start over again? They will be pissed off, as well they should. Not a good way to start their FreeCAD experience!!!
Third, you can install a 32-Bit program on a 64-Bit operating system, but the opposite is not true.
Fourth, how many people actually know the distinction between 32-Bit and 64-Bit, and how many know which version their Windows PC is? Not many.
All these facts point to only one logical conclusion: if only a single version is to be proposed, then it MUST be the 32-Bit version, because it will run on any machine. Let the more technical users find out by themselves if there's a 64-Bit version available.
As I said already, the REAL problem we have is that the x86 installer is compiled with the prehistoric OCC 6.5.0, while the x64 version is compiled with 6.6.0. I am still saying this:
I agree that having a dedicated Windows packager would help a lot.normandc wrote:The true solution would be to recompile the 32-Bit and 64-Bit with the latest OCC available (6.7.x).
On a side note, my work PC was changed last year, and I got a Windows 7 64-Bit system. Office suite included was Microsoft Office 2013 32-Bit. And it works perfectly fine... well let me rephrase that: it performs exactly as you would expect from Microsoft software.
