Civil Engineering Design functions
- microelly2
Re: Civil Engineering Design functions
It seems to be UTM coordinates.
Is the position right?
- bn_999(009).png (68.32 KiB) Viewed 3990 times
Yes.It seems to be UTM coordinates.
- microelly2
I will add a converter between UTM ( x+y = right+north) and OSM GMX (latitude, longitude) ...
Then both data models can cooperate.
How do you converter UTM and OSM GMX?I will add a converter between UTM ( x+y = right+north) and OSM GMX (latitude, longitude) ...
How do you have Z= 32N of UTM (WGS84) ?
- microelly2
http://www.rcn.montana.edu/resources/converter.aspxserviteur wrote: How do you converter UTM and OSM GMX?
- microelly2
Because Openstreeetmap elevation data are still sparse and the access to google data is restricted I have started to play with SRTM Data.
http://wiki.openstreetmap.org/wiki/DE:SRTM
there is a nice site with data converted to OSM format in a 1° grid: http://geoweb.hft-stuttgart.de/SRTM/srtm_as_osm/
I have tested the file for my "backcountry" Lat50Lon11Lat51Lon12.osm.zip
A 5 MB zip file creates the model in FreeCAD with 30 MB.
It contains about 350 000 points on 3900 height lines.
This is a step to use more detailed information which is available for the whole world.
- bp_048.png (104.97 KiB) Viewed 3870 times
- microelly2
There is a new function in the geodata workbench to get the elevation data from a free source.
Its still not the whole data volume but it can be combined with individual collected data from gps tracks, here an example with an older dataset. methods to combine datasets for better approximations of the skin will follow.
then I will install some geocaches that can only be found after solving a puzzle with the use of FreeCAD
https://www.youtube.com/watch?v=cam4znHqMOI
https://github.com/microelly2/geodata
- microelly2
attached a file of terrain lines imported by dxf. Is it possible with the geodat module to make a shell out of this lines? At the end I woul like to have a terrain solid to work with.
bernd
bernd
- microelly2
It's still only an elevation grid but you can set the gridClount higher to get a finer surface.
#: utf-8 -*-
#-- reconstruction workbench
#-- microelly 2016 v 0.1
#-- GNU Lesser General Public License (LGPL)
# interpolate point cloud to a quad mesh face
# http://forum.freecadweb.org/viewtopic.php?f=13&t=15988
import FreeCAD, Draft
import FreeCADGui
Gui=FreeCADGui
App=FreeCAD
import numpy as np
import matplotlib.pyplot as plt
import scipy.interpolate
import Points
# test data
datatext='''1 1 1
1 2 1
1 3 1
1 4 1
1 5 1
1 6 1
1 7 1
1 8 1
1 9 1
1 10 1
2 1 1
2 2 1
2 3 1.2
2 4 1.2
2 5 1.2
2 6 1
2 7 1
2 8 1
2 9 1
2 10 1
3 1 1
3 2 1
3 3 1.2
3 4 1.3
3 5 1.2
3 6 1
3 7 1
3 8 1
3 9 1
3 10 1
4 1 1
4 2 1
4 3 1.2
4 4 1.2
4 5 1.2
4 6 1
4 7 1
4 8 1
4 9 1
4 10 1
5 1 1
5 2 1
5 3 1
5 4 1
5 5 1
5 6 1
5 7 1
5 8 1
5 9 1
5 10 1
6 1 1
6 2 0.9
6 3 0.9
6 4 0.9
6 5 1
6 6 1
6 7 1
6 8 1
6 9 1
6 10 1
7 1 1
7 2 0.9
7 3 0.8
7 4 0.9
7 5 1
7 6 1
7 7 1
7 8 1
7 9 1
7 10 1
8 1 1
8 2 0.9
8 3 0.9
8 4 0.9
8 5 1
8 6 1
8 7 1
8 8 1
8 9 1
8 10 1
9 1 1
9 2 1
9 3 1
9 4 1
9 5 1
9 6 1
9 7 1
9 8 1
9 9 1
9 10 1
10 1 1
10 2 1
10 3 1
10 4 1
10 5 1
10 6 1
10 7 1
10 8 1
10 9 1
10 10 1
def text2coordList(datatext):
x=[]; y=[]; z=[]
if len(datatext) <> 0:
lines=datatext.split('\n')
for zn,l in enumerate(lines):
words=l.split()
try:
[xv,yv,zv]=[float(words[0]),float(words[1]),float(words[2])]
# print xv+yv+zv
x.append(xv)
y.append(yv)
z.append(10*zv)
except:
print "Fehler in Zeile ",zn
x=np.array(x)
y=np.array(y)
z=np.array(z)
#x=x-x.min()
#y=y-y.min()
return (x,y,z)
# x,y,z= text2coordList(datatext)
def points2coordList(points):
''' convert Pointsobject to numpy 1D-arrays of coordinates '''
x=np.array([ p[0] for p in points])
y=np.array([ p[1] for p in points])
z=np.array([ p[2] for p in points])
return x,y,z
# x,y,z= points2coordList(p.Points)
def coordLists2points(x,y,z):
''' convert coordinate lists to Points '''
p=Points.Points()
pts=[]
try:
# simple list
n=len(x)
except:
# numpy
n=x.shape(0)
for i in range(n):
pts.append(FreeCAD.Vector(y[i],x[i],z[i]))
p.addPoints(pts)
return p
# p= coordLists2points(x,y,z)
def interpolate(x,y,z, gridsize,mode='thin_plate',rbfmode=True,shape=None):
grids=gridsize
dx=np.max(x)-np.min(x)
dy=np.max(y)-np.min(y)
if dx>dy:
gridx=grids
gridy=int(round(dy/dx*grids))
else:
gridy=grids
gridx=int(round(dx/dy*grids))
if shape<>None:
(gridy,gridx)=shape
xi, yi = np.linspace(np.min(x), np.max(x), gridx), np.linspace(np.min(y), np.max(y), gridy)
xi, yi = np.meshgrid(xi, yi)
if rbfmode:
rbf = scipy.interpolate.Rbf(x, y, z, function=mode)
rbf2 = scipy.interpolate.Rbf( y,x, z, function=mode)
else:
print "interp2d nicht implementiert"
rbf = scipy.interpolate.interp2d(x, y, z, kind=mode)
zi=rbf2(yi,xi)
return [rbf,xi,yi,zi]
def showFace(rbf,rbf2,x,y,gridsize,shapeColor):
import Draft
grids=gridsize
ws=[]
xi, yi = np.linspace(np.min(x), np.max(x), grids), np.linspace(np.min(y), np.max(y), grids)
for ix in xi:
points=[]
for iy in yi:
# print (ix,iy, rbf(ix,iy))
iz=float(rbf(ix,iy))
# if rbf2<>None:
# iz -= float(rbf2(ix,iy))
points.append(FreeCAD.Vector(iy,ix,iz))
w=Draft.makeWire(points,closed=False,face=False,support=None)
ws.append(w)
#- FreeCAD.activeDocument().recompute()
#- FreeCADGui.updateGui()
#- Gui.SendMsgToActiveView("ViewFit")
ll=FreeCAD.activeDocument().addObject('Part::Loft','elevation')
ll.Sections=ws
ll.Ruled = True
ll.ViewObject.ShapeColor = shapeColor
ll.ViewObject.LineColor = (0.00,0.67,0.00)
for w in ws:
w.ViewObject.Visibility=False
ll.Label="Interpolation Gitter " + str(grids)
def showHeightMap(x,y,z,zi):
''' show height map in maptplotlib '''
zi=zi.transpose()
plt.imshow(zi, vmin=z.min(), vmax=z.max(), origin='lower',
extent=[ y.min(), y.max(),x.min(), x.max()])
plt.colorbar()
CS = plt.contour(zi,15,linewidths=0.5,colors='k',
CS = plt.contourf(zi,15,cmap=plt.cm.rainbow,
z=z.transpose()
plt.scatter(y, x, c=z)
# achsen umkehren
#plt.gca().invert_xaxis()
#plt.gca().invert_yaxis()
plt.show()
return
def createElevationGrid(mode,rbfmode=True,source=None,gridCount=20):
modeColor={
'linear' : ( 1.0, 0.3, 0.0),
'thin_plate' : (0.0, 1.0, 0.0),
'cubic' : (0.0, 1.0, 1.0),
'inverse' : (1.0, 1.0, 0.0),
'multiquadric' : (1.0, .0, 1.0),
'gaussian' : (1.0, 1.0, 1.0),
'quintic' :(0.5,1.0, 0.0)
if source<>None:
if hasattr(source,"Shape"):
# part object
pts=[v.Point for v in source.Shape.Vertexes]
p=Points.Points(pts)
Points.show(p)
pob=App.ActiveDocument.ActiveObject
pob.ViewObject.PointSize = 10.00
pob.ViewObject.ShapeColor=(1.0,0.0,0.0)
elif hasattr(source,"Points"):
# point cloud
pts=source.Points.Points
elif source.__class__.__name__ == 'DocumentObjectGroup':
hls=App.ActiveDocument.hoehenlinien
apts=[]
for l in hls.OutList:
pts=[v.Point for v in l.Shape.Vertexes]
apts += pts
pts=apts
else:
raise Exception("don't know to get points")
x=[v[1] for v in pts]
y=[v[0] for v in pts]
z=[v[2] for v in pts]
else:
# testdata
x=np.array(x)
y=np.array(y)
z=np.array(z)
gridsize=gridCount
rbf,xi,yi,zi1 = interpolate(x,y,z, gridsize,mode,rbfmode)
# hilfsebene
xe=[100,-100,100,-100]
ye=[100,100,-100,-100]
ze=[20,10,20,5]
rbf2,xi2,yi2,zi2 = interpolate(xe,ye,ze, gridsize,mode,rbfmode,zi1.shape)
#print zi1.shape
#print zi2.shape
#zi=zi1-zi2
zi=zi1
try: color=modeColor[mode]
except: color=(1.0,0.0,0.0)
xmin=np.min(x)
ymin=np.min(y)
showFace(rbf,rbf2,x,y,gridsize,color)
# interpolation for image
gridsize=400
rbf,xi,yi,zi = interpolate(x,y,z, gridsize,mode,rbfmode)
rbf2,xi2,yi2,zi2 = interpolate(xe,ye,ze, gridsize,mode,rbfmode,zi.shape)
return [rbf,rbf2,x,y,z,zi,zi2]
if 0 and __name__ == '__main__':
createElevationGrid('thin_plate')
createElevationGrid('linear')
createElevationGrid('inverse')
createElevationGrid('multiquadric')
createElevationGrid('gaussian')
App.activeDocument().recompute()
# radial basis function interpolator instance
# http://docs.scipy.org/doc/scipy/reference/generated/scipy.interpolate.Rbf.html
source=App.ActiveDocument.hoehenlinien
# createElevationGrid('multiquadric',True,"gruppe")
#createElevationGrid('linear',True,source,50)
#createElevationGrid('linear',True,source,80)
createElevationGrid('thin_plate',True,source,30)
