short cut for workbenches
In the following post (viewtopic.php?f=21&t=7559#p61711) something I have been thinking about quite a few times allready has been mentioned. Short cuts for changing workbenches. Has this been discussed allready? Do there exists some short cuts for the wbs allready?
Re: short cut for workbenches
in the Assembly branch, automatic wb switch has been enabled to a limited extent....so if you edit something it automatically switches to the appropriate wb for that item. It seemed to work quite well within the limited testing I did.
You still have to manually change to an appropriate wb to create something in the first place of course.
I mostly switch between. Part an Arch. Is it worth to make a Mantisentry?
Hello Bernd.
That depends.
I switch a lot between different workbenches.
Having them on the F1-F12 keys would be GREAT.
Also i would like to know if there is any news on reducing toolbar space ?
Roland
That depends.
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Not a good idea to use F-keys because only 12 wbs could be addressed and it is not easy to keep in mind which F-key is which wb. My opinion.r-frank wrote:... Having them on the F1-F12 keys would be GREAT. ...
I was not aware of the thread viewtopic.php?f=8&t=7339&hilit=switch+removed&start=10
But if the switcher is in the menue a alt+w+wbletter would switch the wb. That will do the trick.
Note that a very simple macro containing one line would do the job...
I'm not too sure how heavy would be the work needed to add keyboard shortcuts to workbenches, though...
FreeCADGui.activateWorkbench("ArchWorkbench")
Well that would be great, though. I think this should be fully configurable in the preferences, and we can discuss only about the default. There won't ever be a single set of keys satisfying all users.
Ciao
Enrico
Ciao
Enrico
Guys, Jürgen has already plans to replace the workbench switcher with a dedicated menu. With a menu, keyboard shortcuts will be possible.
There's a discussion about it on the "Development" section, but I can't try to locate it ATM.
