Hey,
Currently starting to write a thesis comparing manifold and non-manifold modelling and which to inquire, does FreeCAD support non-manifold modelling?
All the best
Does FreeCAD support non-manifold modelling?
Re: Does FreeCAD support non-manifold modelling?
If you work mainly in python and not with the GUI you might be able to some useful things with non-mainfold geometry.
But most of the tools in the GUI are meant to work on solids. (which, by definition, need to be mainfold).
I would say: Though FreeCAD might be useful in come cases, non-mainfold modelling is out of it's focus, and is clearly not supported.
A typical example is out sketcher. New users sometimes create non-mainfold sketches. But those can not be extruded (or padded) to a solid by our geometric modeling kernel. The result is a having the edges of the sketch extruded individually (to faces). But in the context of the usual work flows, this result is mostly useless.
Hello.
Since I am german and eager to learn something I first wanted to know what a non-manifold is.
So I found this document.
Looking at the Pictures "Non-Manifold Vertex in a Face" and "Non-Manifold Edge in a Solid" I would say:
> Circles or cylinders touching each other are mathematically spoken extra cases
> if the CAD-Core (in our case OCC) supports it you probably won't be able to do this Operation
in one single step
> but this is an interesting Point. ATM I don't have Access to FreeCAD but if time permits, i will do some
tests and report back
Roland
in one single step
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Anyone have any advice on a good open source CAD package for non manifold modelling?
All the best
All the best
I'm sorry but CAD and non-manifold are totally, completely and absolutely antagonistic.
In CAD you try to avoid non-manifold like the plague. In fact all the CAD programs I know of will flat out refuse an operation that would generate a non-manifold object. That's because CAD is almost solely focused on real world design, and to my knowledge there is no case where a non-manifold object is desirable.
