Support for assembly2 continuing
Re: Support for assembly2 continuing
yes you can:
- go to the Assembly2 workbench
- right click on the constrainte -> "Assembly2" -> "Select Object Elements"
The components on which the constrainte is based on are highlighted
Paul
Paul
- capture_freecad.png (119.19 KiB) Viewed 3417 times
Merci de l'information.
Je retroune pour faire tourner mon servo moteur.
Bonne journée.
Bonne journée.
jbe,
This is an English language forum. Have the courtesy to reply in English so that all users can understand.
You should know better. Seriously.
Thank you for this information.
I go back to Freecad with Animation module for servomotor.
Best regard.
Best regard.
PR for Assembly2 aligned to new Part.Line behavior FC_0.17r-frank wrote: Roland
https://github.com/hamish2014/FreeCAD_a ... 2/pull/130
FC forum references
https://forum.freecadweb.org/viewtopic. ... 81#p159865
https://forum.freecadweb.org/viewtopic. ... 50#p159832
thx to @agryson Assembly2 workbench icons are now aligned to the main FreeCAD artwork guidelines
FreeCAD_assembly2/pull/132
Very nice work Alex!
Looking good.
I don't understood the tool : Set lockRotation->True for the last constraint add.
Do you have an example ?
Best regard
Best regard
A bolt/screw.jbe wrote:Do you have an example ?
While axial constraint leave the rotational DOF ...
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
