Bore feature
Bore feature
I created a new feature for making holes (standard, nonstandard, with and without thread, counterbored, countersunk etc.) Its on github jrheinlaender/FeatureBore and it is written in python.
Now I have a question for the native English speakers: Should the feature be called
bore
hole
borehole, bore-hole, bore hole
perforator
Thanks for some enlightenment on this confusion!
And I just saw that the feature works great with Box, Cylinder etc. but if I sketch a pad of the same dimensions (!) it has tons of issues with the boolean operation... <
bore
hole
perforator
Re: Bore feature
Online translator says: bore hole and borehole
http://dict.tu-chemnitz.de/dings.cgi?la ... nt=&email=
Re: Bore feature
Looks interesting, especially done in python!
Well done jrheinlaender once again!
Pretty much all have the same meaning. Bore holes tend to be used with drilling through earth. Then again a hole is not the same as being countersunk. I'd probably go with Bore, but that's just an opinion.jrheinlaender wrote:borehole, bore-hole, bore hole
Development blog - http://freecadamusements.blogspot.co.uk/
Re: Bore feature
In SolidWorks it's called "hole wizard" or something like that. Maybe thinking about manufacturing it should be called "drill feature" don't you think?
Re: Bore feature
In CATIA it's also called Hole. Searching in dictionary (British type) the best option seems be hole, because bore is more associated with drill. In design, there are Holes, in manufacturing, there are drills. This feature is part of design.
Re: Bore feature
In Pro/E, I think it's called a Hole feature.
Re: Bore feature
I have not looked the code yet but how do you store the thread and standard hole dimensions?
Do you use a file (xml type) or a DB?
Re: Bore feature
Its hardcoded in the python. Reason see this thread (note that my favoured solution was a DB):
viewtopic.php?f=10&t=3296
Re: Bore feature
Great work! I use this feature frequently in other software, glad to see it come to FreeCAD.
Name wise, my machinist and my design handbooks both call it a counterbore. Autodesk Inventor just calls it "Hole". I think any name would be good, especially if we have an intuitive icon to go with it.
Re: Bore feature
I really like this feature. You have done a great job with it.
Have you tried using it with a linear or polar pattern yet? I wasn't able to get that to work out for me. It seems that it is referencing itself, and not the parent part, but I might be doing things wrong.
Thanks for making this feature!
