[Closed]Test Create ArchRebar2 Object
chakkree
Post by chakkree »
from ArchPrecast + ArchRebar, I try to create reinforcing bar object.
First, Sample is U-Shape rebar.
import ArchCommands,ArchComponent,FreeCAD
from FreeCAD import Vector
import Draft
import DraftGeomUtils
class _Rebar(ArchComponent.Component):
    def __init__(self,obj):
        ArchComponent.Component.__init__(self,obj)
        obj.addProperty("App::PropertyDistance","diameter","Rebar","The diameter of this rebar")
        obj.Role = ['Rebar']
        self.Type = "Rebar"
    def getProfile(self,obj,noplacement=True):
        return []
    def getExtrusionVector(self,obj,noplacement=True):
        return FreeCAD.Vector()
    def execute(self,obj):
        if self.clone(obj):
            return
class _Rebar_U_shape(_Rebar):
        _Rebar.__init__(self,obj)
        obj.addProperty("App::PropertyDistance","A","Rebar","The A length of this rebar")
        obj.addProperty("App::PropertyDistance","B","Rebar","The B length of this rebar")
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        import Part
        points = []
        points.append(Vector(0,0,A))
        points.append(Vector(0,0,0))
        points.append(Vector(B,0,0))
        points.append(Vector(B,0,A))
        lines = []
        for i in range(1, len(points)):
            lines.append(Part.Line(points[i],points[i-1]))
        spath = Part.Shape(lines)
        wpath  = Part.Wire(spath.Edges)
        wire = Part.Wire(wpath)
        wire = DraftGeomUtils.filletWire(wire,R)
        bpoint = points[0]
        bvec = points[1].sub(points[0]).normalize()
        circle = Part.makeCircle(dia/2,bpoint,bvec)
        circle = Part.Wire(circle)
        bar = wire.makePipeShell([circle],True,False,2)
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
class _ViewProviderRebar(ArchComponent.ViewProviderComponent):
    def __init__(self,vobj):
        ArchComponent.ViewProviderComponent.__init__(self,vobj)
        vobj.ShapeColor = (0.67,0.00,0.00)
    def getIcon(self):
        import Arch_rc
        return ":/icons/Arch_Rebar_Tree.svg"
def makeRebar2(dia=12 , A=300 , B=1000 , placement = (0,0,0) ):
    obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Reinforcing Bar")
    _Rebar_U_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    obj.Placement.Base = Vector(placement)
    if FreeCAD.GuiUp:
        _ViewProviderRebar(obj.ViewObject)
    return obj
if __name__=="__main__":
    rebar1 = makeRebar2()
    rebar2 = makeRebar2(placement = (0, 500, 0))
    rebar3 = makeRebar2(dia= 25 , placement = (0, 1000, 0))
    rebar4 = makeRebar2(dia= 32  , A = 500 , B = 1200, placement = (0, 1500, 0))
    FreeCAD.ActiveDocument.recompute()
    Msg("\nDone!!\n\n")
TestArchRebar2_01.FCStd
(9.26 KiB) Downloaded 78 times
Re: Test Create ArchRebar2 Object
Post by yorik »
Good test! I haven't tried yet to put rebars in precast elements. Normally it should work, but we never know...
chakkree
Post by chakkree »
new class object in ArchRebar2.py -> Stirrup Type 1
   ArchRebar2.py
import Draft
        self.Type = "Rebar"
        return []
    def setShapeCode(self , ShapeCode):
        pass
        if self.clone(obj):
            return
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        import Part
        points = []
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
class _Rebar_Stirrup(_Rebar):
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 4*dia /2.
        import Part
        points = []
        points.append(Vector(-A/2.,+B/2.-R-12*dia,0))
        points.append(Vector(-A/2.,+B/2.,0))
        points.append(Vector(+A/2.,+B/2.,0))
        points.append(Vector(+A/2.,-B/2.,0))
        points.append(Vector(-A/2.,-B/2.,+dia))
        points.append(Vector(-A/2.,+B/2.,+dia))
        points.append(Vector(-A/2.+R+12*dia,+B/2.,+dia))
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
    def getIcon(self):
        import Arch_rc
    _Rebar_U_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
def makeStirrup(dia=6 , A=150 , B=350 , placement = (0,0,0) ):
    obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Stirrup")
    _Rebar_Stirrup(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
    #rebar1 = makeRebar2()
    #rebar2 = makeRebar2(placement = (0, 500, 0))
    #rebar3 = makeRebar2(dia= 25 , placement = (0, 1000, 0))
    #rebar4 = makeRebar2(dia= 32  , A = 500 , B = 1200, placement = (0, 1500, 0))
    spacing = 125
    for z in range(150,3000-150 , spacing):
        stirrup1 = makeStirrup(A=150, B = 150 ,placement = (0, 0, z))
        stirrup1.ViewObject.ShapeColor=(0.67,1.00,0.50)
    Msg("\nDone!!\n\n")
TestArchRebar2_02.FCStd
(70.56 KiB) Downloaded 68 times
chakkree
Post by chakkree »
Stirrup Type 2
   ArchRebar2.py
import Draft
from math import cos , radians
        self.Type = "Rebar"
        return []
        pass
        if self.clone(obj):
            return
        points = []
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 5*dia /2.
        import Part
        points = []
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
        obj.addProperty("App::PropertyEnumeration","Type","Rebar","The Type of hook rebar")
        obj.Type = ['1','2']
        if self.clone(obj):
            return
        pl = obj.Placement
        dia = obj.diameter
        A = obj.A
        B = obj.B
        R = 4*dia /2.
        import Part
        points = []
        if obj.Type=='1':
        elif obj.Type=='2':
            Msg('Type=2\n')
            x = -A/2.; y =+B/2.
            dy = R + R* cos(radians(45))
            x1 = x + R - R* cos(radians(45))
            y1 = y - dy
            l_hook = 6*dia*cos(radians(45))
            points.append(Vector(x1+l_hook ,y1-l_hook,0))
            points.append(Vector(x1-dy,y,0))
            #points.append(Vector(-A/2.,+B/2.,0))
            x1 = x + R + R* cos(radians(45))
            y1 = y - R + R* cos(radians(45))
            points.append(Vector(x,y1+dy,+dia))
            points.append(Vector(x1+l_hook,y1-l_hook,+dia))
        lines = []
        bpoint = points[0]
        shapes = []
        shapes.append(bar)
        obj.Shape = bar
    def getIcon(self):
        import Arch_rc
    _Rebar_U_shape(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    if FreeCAD.GuiUp:
    return obj
def makeStirrup(dia=6 , A=150 , B=350 , Type='1' , placement = (0,0,0) ):
    _Rebar_Stirrup(obj)
    obj.diameter = dia
    obj.A = A
    obj.B = B
    obj.Type = Type
    if FreeCAD.GuiUp:
    return obj
    spacing = 100
        stirrup1 = makeStirrup(A=150, B = 150, Type='2' ,placement = (0, 0, z))
    Msg("\nDone!!\n\n")
TestArchRebar2_StirrupType2.FCStd
(100.92 KiB) Downloaded 73 times
chakkree
Post by chakkree »
Reinforcement in Simple Beam.
TestArchRebar2_SimpleBeam.FCStd
(146.7 KiB) Downloaded 76 times
chakkree
Post by chakkree »
to test footing reinforcement used U-shape rebar + stirrup type 1
TestArchRebar2_Footing.FCStd
(20.88 KiB) Downloaded 80 times
TestArchRebar2_Footing3.FCStd
(97.62 KiB) Downloaded 79 times
chakkree
Post by chakkree »
Now (14 Aug 2016) All above source code can not work correctly on FreeCAD 0.17.8203(approx.)
But All above source code can run correctly on FreeCAD 0.16
chakkree
Post by chakkree »
From this forum "Part.makeTube" locking up then crashing FreeCAD, can work on FreeCAD 0.16 and FreeCAD 0.17.
I'll try to replace code from that to ArchRebar2 class object.
Post by bernd »
Wow, very cool !!! we should integrate this kind of stirups in the FreeCAD gui. It is not possible to do the in scetcher. viewtopic.php?f=23&t=16375#p129608
