"Solid" clipping plane
pablogil
Post by pablogil »
I really like and often use the clipping plane but I don't like how it cuts the solids, I mean, if it's a solid the cut is supposed to continue solid and, therefore show a "solid cutted part"... something like:
Would it be easy to code? and, is it interesting also for you?
Thanks
looo
Re: "Solid" clipping plane
Post by looo »
This would be nice to have (especially for sketching on an object). But I don't think coin already provides some methods for this. Maybe it's possible to write an extension for coin. I think the right way to do it is described here: https://www.opengl.org/archives/resourc ... ode10.html
there was already a topic about this: viewtopic.php?f=3&t=4371
pablogil
Post by pablogil »
looo wrote:This would be nice to have (especially for sketching on an object). But I don't think coin already provides some methods for this. Maybe it's possible to write an extension for coin. I think the right way to do it is described here: https://www.opengl.org/archives/resourc ... ode10.html
Wow, thanks for pointing me out this old thread, I have no tried seeing if there was a previous one about the subject... sorry about that.
I have also read the OpenGL method you linked and seems a nice and probably easy way to accomplish it but I'm not programmer so I have no idea, any of you?
Thanks
ickby
Post by ickby »
It is a bit more complicated. The thing is that the shown stencil technique works with the opengl objects, hence this happens for every object that gets clipped. In FreeCAD however this makes only sense for solids. Not for Meshes or Shells, which are by definition void. Hence one would need to create a object dependend clipping system. Otherwise the current situation would just be inverted, from "Why are Solids shown void?" to "Why are empty objects shown filled?".
Post by bernd »
There is a work around. In preferences 3D view deactivate the backlight color. In the view properties of the cliped object change Lighning from Two side to one side. The inner part of the object will be black thus it looks like the cut plan is black.
pablogil
Post by pablogil »
ickby wrote:It is a bit more complicated. The thing is that the shown stencil technique works with the opengl objects, hence this happens for every object that gets clipped. In FreeCAD however this makes only sense for solids. Not for Meshes or Shells, which are by definition void. Hence one would need to create a object dependend clipping system. Otherwise the current situation would just be inverted, from "Why are Solids shown void?" to "Why are empty objects shown filled?".
I understand but maybe an simple checkbox in the Clipping plane tool to turn it off and on could do the trick. Then it would turn not into if the concept is wrong or not, but how the user wants to view this specific cut...
bernd wrote:There is a work around. In preferences 3D view deactivate the backlight color. In the view properties of the cliped object change Lighning from Two side to one side. The inner part of the object will be black thus it looks like the cut plan is black.
Yes, I saw it on the link @loo shared with me, a really clever trick but it only works with one clipping, if you turn, for instance, two of them then you can "see" the trick:
looo
Post by looo »
Are you sure this is true? With pivy it's possible to add a SoClipPlane as a node somewhere in the scenegraph. Only nodes after the clip-plane are shown clipped.
And the stencil-technique is applied to one plane if I understand it. So if we can figure out the opengl plane corresponding to the SoClipPlane it should be possible to "close" only the clipped solid.
from pivy import coin
import FreeCAD as App
import FreeCADGui as Gui
doc = App.newDocument()
sg = Gui.ActiveDocument.ActiveView.getSceneGraph()
root = coin.SoSeparator()
sphere = coin.SoSphere()
cube = coin.SoCube()
normal = coin.SbVec3f(0,0, 1)
point = coin.SbVec3f(0, 0, 0)
plane = coin.SbPlane(normal, point)
clip = coin.SoClipPlane()
clip.plane = plane
trans = coin.SoTransform()
trans.translation.setValue(coin.SbVec3f(2, 0, 0))
sg.addChild(cube)
sg.addChild(clip)
sg.addChild(trans)
sg.addChild(sphere)
I am now trying to add the opengl stencil-buffer technique which can be found here. First I wanted to try it with PyOpenGl. But the problem I encounter is this line in the example:
EarthSurface->Draw();
I think this should be equivalent to rendering the scene behind the clipped plane. But somehow I can't apply the SoGLRenderAction at a node which is not the root.
looo
Post by looo »
Maybe this is what I need: SoNode::GLRenderBelowPath
But also this doesn't work with python:
  File "SoClipPlane.py", line 49, in myCallbackRoutine
    cap.stencilBuffer(action)
  File "SoClipPlane.py", line 28, in stencilBuffer
    self.node.GLRenderBelowPath(action)
  File "~/conda/envs/freecad/lib/python3.5/site-packages/pivy/coin.py", line 4804, in GLRenderBelowPath
    return _coin.SoNode_GLRenderBelowPath(self, action)
TypeError: in method 'SoNode_GLRenderBelowPath', argument 2 of type 'SoGLRenderAction *'
ickby
Post by ickby »
I'm not really sure, I'm not very familiar with OpenGL. But i always thought that the opengl clipping works on the whole scene. Don't know how coin does handle it with it's clipping. But would be nice if you find a way to make this work :)
looo
Post by looo »
ickby wrote:Don't know how coin does handle it with it's clipping. But would be nice if you find a way to make this work
Ok, a basic example works now:
https://github.com/looooo/pivy/blob/mas ... ipPlane.py
With OpenGL it works this way:
1. draw front faces and decrease stencil-buffer where the front_face is drawn
2. disable drawing to Color-buffer and draw the back-face to the stencil-buffer (increase)
3. render a plane where the stencil-buffer is not 0 (for a solid this is every location where only the back-face is visible)
The trick to not clip the whole scene is to enable a clip plane somewhere in the render-transversal and disable after a certain node/group is drawn.
How to implement this in coin is another question but I think by looking at the implementation of the SoClipPlane this shouldn't be a too big problem. Another thing I was reading about is the use of SoOffScreenRenderer with the stencil-buffer.... https://github.com/looooo/coin3d/blob/m ... p#L219L237
