Boat design
JMG
Boat design
Post by JMG »
Hello.
I want to show you some screenshots of my ongoing design of a 5.8 meter boat that I will try to build for this summer. It is fully made in FreeCAD :D
Javier.
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
Re: Boat design
Post by yorik »
Very nice! do you plan to use the ship module?
JMG
Re: Boat design
Post by JMG »
Thanks Yorik, and yes, I'm using the ship module to analyze buoyancy and stability, very useful workbench! :)
atzensepp
Re: Boat design
Post by atzensepp »
Hello JMC,
wow, this model is impressive! Did you use an existing boat design or did you create it by yourself?
Actually I would like to know how you made it.
Did you create the ribs with Sketcher? How was the surface made?
Did you use the Half-Hull Macro?
atzensepp
JMG
Re: Boat design
Post by JMG »
Hello atzensepp.
It is fully made with the FreeCAD existing tools. The hull is made with a loft through 8 sketches, then I explode the solid into faces and I start to build the ribs and other parts. The only cheat I did was a small script to clone and place the 8 sketches in line with a given distance.
I will do a tutorial once I completely undestand the ship module.
Javier.
atzensepp
Re: Boat design
Post by atzensepp »
Hello Javier,
JMG wrote: It is fully made with the FreeCAD existing tools. ...
Javier.
It is fantastic what can be done with pure FreeCAD board means. One has "only" to know them.
JMG wrote: I will do a tutorial once I completely undestand the ship module.
Javier.
This will be great!
Thank you for your answers.
aztensepp
TT-RS
Re: Boat design
Post by TT-RS »
Nice concept, I like it much.
clintonsam75
Re: Boat design
Post by clintonsam75 »
That looks very cool. 8-)
janeks
Re: Boat design
Post by janeks »
Looks nice!
I am planning to make similar boat design. Idea is to use plywood for ribs cover.
Finally I would like to get some flat plans for plywood sheets. F.ex. to feed in CNC (or at least to draw on plywood sheets).
So the question is how to create them from convex hull part/surface?
brgds
Janeks
zumer
Re: Boat design
Post by zumer »
janeks wrote:Looks nice!
Janeks
To be developable, they must be simplified to single curvature. One way is to slice the hull bread-and-butter orthographically (boolean surface intersection with an appropriate object) and loft ruled surfaces for the slices.
