Developer advice needed for InputFields
I have worked on the problem of unwanted x10 multiplication in input fields occuring here and there in FreeCAD. I have a solution, but to make it clean and globally available it would be very kind if one of the experienced developers could give me a helping hand and give me some hints: viewtopic.php?f=10&t=18833&start=10#p152007.
Thank you.
mlampert
Re: Developer advice needed for InputFields
Post by mlampert »
Hey Chris, we just discovered the InputField and are starting to convert to it. While some dialogs in Path currently use it most of them treat it like a text field. What we should really do is use Units.Quantity to convert to and from strings.
So if there is a distance or length the conversion we should set the display string to
inputFieldWidget.setText(FreeCAD.Units.Quantity(<value>, FreeCAD.Units.Length).UserString)
And again, to retrieve the value from an input field:
FreeCADUnits.Quantity(inputFieldWidget.text()).Value
sebste
Post by sebste »
I was playing with it a bit last night and applied the changes mlampert suggested while sliptonic pointed me into the right direction on IRC.
https://github.com/FreeCAD/FreeCAD/pull/427
I hope it is helpful and I have got the git / pull request stuff right.
Cheers
That's phantastic. I had promised a week and thought it would be fast enough and now it is done after one day. I would like to see a commercial program having that speed.
sebste
PR430 / more fixes in TooltableEditor (Re: Developer advice needed for InputFields)
Post by sebste »
Found the same issue in the TooltableEditor and fixed within
https://github.com/FreeCAD/FreeCAD/pull/430
Also fixed export / import of tool tables to handle non-ascii characters in filenames, added exception handling for reading and writing and fixed german translation string that broke file type selection filter in file open dialog.
At this occasion, I stumbled across some more unicode issues with the Toolnames. Since the QStrings are cast to Strings, they cant handle non-ascii characters. Casting with unicode() does not work, probably because the Tool class is defined in c++ and name is of type char? Any Ideas on how to deal with this?
I would strongly recommend avoiding casting QStrings from Gui imput to String, as it will likely cause trouble with unicode characters. As I general rule of thumb, I have learned, that in Python2, QStrings should be cast to Unicode at the earliest time possible. Is there a convention within FreeCAD, if not, should there be one? What do you think?
I hope this helps a bit. This git / PR stuff and working on code with others is pretty new to me, so please bear with me and let me know if I got something wrong.
Cheers
Sebastian
Post by wmayer »
Your PR is broken and has some merge conflicts.
What do you mean with casting a QString to a string? And are you talking about C++ now or Python?
Anyway, inside C++ it's always safe to convert a QString to utf8-encoded char* by using toUtf8() and fromUtf8(). If a utf8-encoded string gets serialized e.g. by macro recording then it's recommended to "escape" it using the method escapedUnicodeFromUtf8 (defined inside src/Base/Tools.h).
The convention is that any string coming from user input (path names, text, ...) must be considered as unicode text and if passed to a function that expects a char* then toUtf8()/fromUtf8() must be used. If it's clear that a text is 7-bit ASCII then toLatin1()/fromLatin1() are allowed.
If in C++ we have a utf8 string and call a Python function then the string should be escaped and inside Python handled as a unicode object.
        std::string unicodepath = Base::Tools::escapedUnicodeFromUtf8((*it).toUtf8().data());
        openCommand("Import Mesh");
        doCommand(Doc,"import Mesh");
        doCommand(Doc,"Mesh.insert(u\"%s\")",
                  unicodepath.c_str());
        commitCommand();
If we have a Python binding function written in C/C++ and invoked from within Python then e.g. path names are expected to be in unicode and try to convert them to utf8
        char* Name;
        if (!PyArg_ParseTuple(args.ptr(), "et","utf-8",&Name))
            throw Py::Exception();
        std::string EncodedName = std::string(Name);
        PyMem_Free(Name);
sebste
Post by sebste »
Thanks, for the heads up. I am sorry. I know what a merge conflict is in theory, but I have no clue how this happened and how to actually solve this. Any hints would be much appreciated :oops:
I was talking Python / PyQt. Normally when I get input from let's say a QLineEdit, In Python2, I immediately do unicode(lineEdit.text()) (as recommended in "Rapid GUI programming with Python and Qt"). Obviously if the data is handed to a char* this does not work.
[/quote]
Thanks, so far so good....
My concrete example that is driving me nuts is in Mod/Path/PathScripts/PathToolLibraryManager.py in line 423
t.Name = str(editform.NameField.text()) #this results in an error with non-ascii characters
As editform.NameField is a QLineEdit, I would expect it to return a QString.
So a fix would be like so:
t.Name = editform.NameField.text().toUtf8()
But this, somehow results in an error, because it actually returns a unicode object (what I think is pretty weird)
So I could do:
t.Name = QtCore.QString(editform.NameField.text()).toUtf8()
whcih should return a QByteArray with my utf8 encoded input.
....but...
apparently in PySide, QtCore does not have a thing called QString (???)
So what actually works fine is this:
t.Name = editform.NameField.text().encode("utf-8")
But that is apparently not the way it should be done, right :-(
mlampert
Post by mlampert »
There is an introduction here: https://help.github.com/articles/resolv ... mand-line/
Personally I like to use meld (meldmerge.org) as the mergetool for git (https://git-scm.com/docs/git-mergetool). Send me a PM, or get on IRC if you have problems and I run you through it.
Post by wmayer »
This of course doesn't work because for PySide text() already returns a unicode object. If this contains non-7-bit-ASCII then str() doesn't know how to handle it. Now I don't know what "t.Name" allows you to assign to it. If it accepts unicode you can write:
t.Name = unicode(editform.NameField.text())
If it doesn't accept unicode you have to write:
t.Name = unicode(editform.NameField.text()).encode("utf-8")
....but...
That's the biggest difference between PyQt and PySide.
sebste
Post by sebste »
Thanks for your help, mlampert!
wmayer:
PR is fixed, now.
So I was not to far off, then :-)
....but...
And the fact that PySide does not work on the console in interactive mode, properly.
I have not done anything with PySide, before and thought it was basically the same as PyQt.
Thanks for enlightening me. I am just digging into the FreeCAD code for a few days and already learned a ton!
