Draft AutoGroup
Info about new implemented features, classes, modules or APIs. Might get technical!
Draft AutoGroup
Postby yorik » Wed Jan 25, 2017 5:09 pm
In git commit 9a6191f572 the Draft workbench now has an additional feature, auto-grouping, that was in the plans since along time, rockn actually developed some of it, and I finally finished it.
It's pretty simple: There is a new button in the Draft toolbar that says "None" by default. If you have any Group object in the document (or derived from Group, or Arch Site, Arch Building or Arch Floor), you can press the button, and select any of them. You can do that also by right-clicking one of them in the tree, Utilities->AutoGroup.
When AutoGroup is set, the button turns green, it means autogrouping is activated. You can click on it to change the group or unset.
When autogrouping is active, any new Draft or Arch object created will be placed in that group (except when Draft construction mode is on, in which case it goes to the construction group).
This only works when creating Draft or Arch objects from the GUI buttons. Not when using them from python. This is so it is still possible for python scripts to do the grouping they want, regardless of what autogrouping says. In python scripts, using Draft autogrouping is simple, one only needs to do:
Draft.autogroup(myObject)
This will take care of everything.
DeepSOIC
Re: Draft AutoGroup
Postby DeepSOIC » Wed Jan 25, 2017 10:46 pm
Problem is, this system is something that needs to be done across whole FreeCAD. Does it work outside of Draft?
EDIT: I see, it is only for Draft. Too bad...
Re: Draft AutoGroup
Postby yorik » Thu Jan 26, 2017 11:36 am
DeepSOIC wrote:Problem is, this system is something that needs to be done across whole FreeCAD. Does it work outside of Draft?
Yes, but it's not that difficult to port to C++ and make available throughout freecad. But I thought it's best to first experiment in a limited area like Draft. because I'm not sure that implementation is the best possible. For example, it would create some headache in PartDesign. And in PartDesign, was introduced the concept of "active host", which is a concurrent idea to this one. So this requires more thinking before anything gets done at freecad level, IMHO
DeepSOIC
Re: Draft AutoGroup
Postby DeepSOIC » Thu Jan 26, 2017 2:49 pm
yorik wrote:And in PartDesign, was introduced the concept of "active host", which is a concurrent idea to this one. So this requires more thinking before anything gets done at freecad level, IMHO
So I'd like to share my vision of it =)
See points 1 and 2 in this post of mine :mrgreen: , in forum thread "Steps forward to assembly infrastructure" :
https://forum.freecadweb.org/viewtopic. ... 64#p140548
Unfortunately, I don't code for FreeCAD right now, so I feel a bit bad about trying to push others to follow my plans. But at least, can be considered.
A short correction, maybe it's better to have App.ActiveDocument.ActiveContainer, not straight App.ActiveContainer.
BTW, I already made Part-o-Magic, which does exactly this (adds new stuff to active container automatically), and works across whole FreeCAD (including any add-on workbenches). Unfortunately, it's more of a hack, and doesn't feel like a good thing to be merged into FreeCAD. And it doesn't support groups (it was made for Part containers), and it's outdated at the moment (not aware of extension framework; I hope to update it soon).
Gift
Re: Draft AutoGroup
Postby Gift » Fri Jan 27, 2017 9:24 pm
It is possible to go the way from the other side with “smart groups”:
* Select the workbench in AutoGroup as property from the group.
* Other selectable features like ExportAutoSelect, Namespace, AutoClone …
* More for icons freaks: Standardized icon for all os. Selectable icons: SketchBox, Templates …
Many greetings from “Industrie-4.0-Germany” :D
HoWil
Re: Draft AutoGroup
Postby HoWil » Thu Apr 13, 2017 7:24 pm
yorik wrote:When AutoGroup is set, the button turns green, it means autogrouping is activated. You can click on it to change the group or unset.
Hi yorik, I tried this feature and do not understand how to exit a selected group. I expected when I select 'None' that new elements are created in the root of my document. But they are not!?
BR,
HoWil
Re: Draft AutoGroup
Postby yorik » Fri Apr 14, 2017 9:42 pm
HoWil wrote:I expected when I select 'None' that new elements are created in the root of my document. But they are not!?
Are you sure? I just tested again here, when selecting "None", the toolbar button turns red again and new objects get created in the doc root as normally...
HoWil
Re: Draft AutoGroup
Postby HoWil » Wed Apr 19, 2017 7:16 pm
Hi Yorik,
Please see the attached screencast:
I would expect that even if construction mode is on and 'None' is selected new elements are created in the root of the model tree:
Accordingly, see the creation of the second line at 0:13 and the creation of the fourth line at 0:23 (after switching back to 'None').
Maybe I did understand the workflow wrong and I always have to switch off construction mode to get back to root, but what is than 'None' for?
BR,
HoWil
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10887 (Git)
Build type: None
Hash: 67fc70dadae471cb3d77dcf5562b4a86ec79f95d
Python version: 2.7.12
OCC version: 7.1.0
Re: Draft AutoGroup
Postby yorik » Sun Apr 23, 2017 10:53 pm
Ok thanks, I see now... There is a conflict between the autogroup and construction mode. I think the best approach would be to 1) when switching the construction mode on, always create a "construction" group, 2) if autogroup is set when switching construction mode on, change the autogroup group to "Construction", and 3) when switching autogroup on, unset construction mode of needed.
However I don't like creating a construction group immediately... User might switch tconstruction mode on, then change his/her mind, and not draw anything, and there would be a leftover empty constuction group there.
