Units for feedrate
Units for feedrate
I still use imperial units for CAM and would like to bring something up about feedrates- in the property panels it seems that there is only 'mm/s' for feedrates for Path operations.
I submitted a bug report on Mantis about this:
[bug]https://www.freecadweb.org/tracker/view.php?id=2890[/bug]
In the past, I think we ignored the units in the feedrates entries in the property panels for operations, but we really should figure out how to fix it. I know it's probably deep in the units source somewhere in the main FreeCAD App directory, but I did a little grepping and can't seem to find where 'mm/s' is coming from.
Re: Units for feedrate
I think the feed rate is just a number and whatever unit the post processor sets is what is being used.
That is true, so maybe the solution is to remove "App::PropertySpeed" from the property panel entry boxes and use "App::PropertyFloat" instead.mlampert wrote:I think the feed rate is just a number and whatever unit the post processor sets is what is being used.
Gotcha' - good point.danielfalck wrote:That is true, so maybe the solution is to remove "App::PropertySpeed" from the property panel entry boxes and use "App::PropertyFloat" instead.
I updated the bug.
Just for my clarification, do you have the global unit options in FC set to metric or are those also in imperial?
I have set my global prefs to imperial.mlampert wrote:I updated the bug.
Interesting, sounds like a bug in InputField. Maybe an oversight of not handling speed according to the global unit and just assuming the default.
I can eradicate all instances of "App::PropertySpeed" if no one objects
I don't understand the consequences, so how could I object? If it is without units I don't see any problem. If it uses units, can we assure they are conforming to the settings in the post processor? Or is it the other way round: the post processor has to be configured so that it matches the units used in the path?danielfalck wrote:I can eradicate all instances of "App::PropertySpeed" if no one objects
The only indicator that there are units involved is in the property panel that has 'mm/s' attached to the entry box for the feed rate. I found that I was having to multiply my desired feed rates by 25.4 to get them to come out to the proper output with my centroid post processor. I had created a function to filter/convert feed units in that post.chrisb wrote:I don't understand the consequences, so how could I object? If it is without units I don't see any problem. If it uses units, can we assure they are conforming to the settings in the post processor? Or is it the other way round: the post processor has to be configured so that it matches the units used in the path?danielfalck wrote:I can eradicate all instances of "App::PropertySpeed" if no one objects
