compile FreeCAD 0.17 with occt 7.1.0 and netgen, script for Xenial and Jessie
Re: compile FreeCAD 0.17 with occt 7.0.0 and netgen, script for Xenial and Jessie
Post by NormandC »
bernd wrote:I made the script for my own. I use vagrant to test FreeCAD in a fresh installed Xenial or Jessie with fresh compiled FreeCAD. For setting up the environment I use this script. I fully understand your opinion.
I'm sorry if I sounded like I was criticizing your script, Bernd, that was not my intention. More like expressing my frustration. As shown above the problem was caused by myself. :roll:
I see that it's pretty easy to delete everything since it's all located in only 2 places, or to run the script again. But I want to try and salvage what I got first.
bernd wrote:I have'nt had the time trying to compile ooct 7.1. :)
Well for anyone interested, I modified your script to download OCCT 7.1.0. I believe triplus has compiled it, and maybe a few others, and it seems to work fine.
Relevant lines to replace:
Lines 86 to 95:
# get OCCT
cd $base_dir
mkdir occt
cd occt
wget "http://git.dev.opencascade.org/gitweb/?p=occt.git;a=snapshot;h=89aebdea8d6f4d15cfc50e9458cd8e2e25022326;sf=tgz"
mv "index.html?p=occt.git;a=snapshot;h=89aebdea8d6f4d15cfc50e9458cd8e2e25022326;sf=tgz" occt.tgz
gunzip occt.tgz
tar xf occt.tar
rm occt.tar
cd occt-89aebde
Lines 137 to 144:
# building OCCT
cd $base_dir
cd occt
mkdir build
cd build
cmake ../occt-89aebde  -DCMAKE_INSTALL_PREFIX:PATH=/opt/local/FreeCAD-0.17 -DUSE_VTK:BOOL=OFF
make -j 4
sudo make install
Post by bernd »
OCCT 7.1 wow I did not know it is that easy ... :D I'm gone updates the script these days ...
Post by NormandC »
bernd wrote:OCCT 7.1 wow I did not know it is that easy ...
I think minor version number changes (7.0.0 --> 7.1.0) can be compatible to the previous release or not, this time it was compatible without modification. :)
Re: compile FreeCAD 0.17 with occt 7.1.0 and netgen, script for Xenial and Jessie
Post by bernd »
updated the scripts to occt 7.1 thanks to Norman. See links in first topic post
@kkremitzki: I still need to have a look at py3 and the other changes
sodelo
Post by sodelo »
For your information, I solved my problem about the QGLFormat error.
I compared the official list of prerequesites to the ones installed by the script and found out libsoqt4-dev was missing.
After correction the compilation and installation have been successful.
Post by NormandC »
sodelo wrote:I compared the official list of prerequesites to the ones installed by the script and found out libsoqt4-dev was missing.
That's really odd because libsoqt4-dev is not even necessary anymore. Where is this official list of prerequisites you speak of? It's outdated.
CharlieMAC
Post by CharlieMAC »
After the download of VTK the script gives an error.
VTK-7.0.0.tar.gz                                100%[=======================================================================================================>]  29.24M   337KB/s    in 62s
2017-02-05 22:18:34 (479 KB/s) - 'VTK-7.0.0.tar.gz' saved [30659751/30659751]
--2017-02-05 22:18:36--  http://git.dev.opencascade.org/gitweb/?p=occt.git;a=snapshot;h=89aebdea8d6f4d15cfc50e9458cd8e2e25022326;sf=tgz
Resolving git.dev.opencascade.org (git.dev.opencascade.org)... 188.165.114.136
Connecting to git.dev.opencascade.org (git.dev.opencascade.org)|188.165.114.136|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/x-gzip]
Saving to: 'index.html?p=occt.git;a=snapshot;h=89aebdea8d6f4d15cfc50e9458cd8e2e25022326;sf=tgz'
index.html?p=occt.git;a=snapshot;h=89aebdea8d6f     [        <=>                                   ]  48.63M   967KB/s    in 57s
2017-02-05 22:19:40 (880 KB/s) - 'index.html?p=occt.git;a=snapshot;h=89aebdea8d6f4d15cfc50e9458cd8e2e25022326;sf=tgz' saved [50988830]
Jessie--FreeCAD_all.sh: 93: Jessie--FreeCAD_all.sh: Syntax error: [b]Bad fd number[/b]
Ideas?
Charlie
CharlieMAC
Apparently, a chmod +x solved the issue. :) :mrgreen:
sodelo
Post by sodelo »
This is what I am refering to:
http://www.freecadweb.org/wiki/index.ph ... pileOnUnix
Debian and Ubuntu
On Debian-based systems (Debian, Ubuntu, Mint, etc...) it is quite easy to get all needed dependencies installed. Most of the libraries are available via apt-get or synaptic package manager.
•build-essential
•cmake
•python
•python-matplotlib
•libtool
either:
•libcoin60-dev (Debian Wheezy, Wheezy-backports, Ubuntu 13.04 and before)
or:
•libcoin80-dev (Debian unstable(Jesse), testing, Ubuntu 13.10 and forward)
•libsoqt4-dev
Jee-Bee
Post by Jee-Bee »
sodelo wrote:This is what I am refering to:
Debian and Ubuntu
•build-essential
•cmake
•python
•python-matplotlib
•libtool
either:
or:
•libsoqt4-dev
That is the 0.16 release information. the 0.17 have different dependencies, at least part of it.
