Modify Path to my needs. How?
jcf
Re: Modify Path to my needs. How?
Post by jcf »
sliptonic wrote:This sounds a lot like another kind of application called a 'conversational cnc' program
Yes, maybe it is close to that.
In Linuxcnc (that I use) I know the possibility to enter Gcode directly. Is that what you mean?
sliptonic
Post by sliptonic »
No. Features is an add-on gui for building gcode programs. I think it was started by the same Russian programmer who wrote the gcode exporter plug-in for Inkscape. I've not used it myself but it has gotten a lot of attention in the Linuxcnc world.
jcf
Post by jcf »
I have found this wiki about path:
https://github.com/yorikvanhavre/FreeCA ... ath-module
Is there a place where I could find some more information?
sliptonic
Post by sliptonic »
jcf wrote:I have found this wiki about path:
You'll have to be more specific about what you're looking for.
Actual written documentation is still lacking so you might be studying source code.
jcf
Post by jcf »
For a start, I have one specific question:
When I press the "Create Contour Path" button, where do I go in PathScripts?
Where is the entry point?
To create a path job, I have done this:
obj = FreeCAD.ActiveDocument.addObject("Path::FeatureCompoundPython", "Job")
PathJob.ObjectPathJob(obj)
PathLoadTool.CommandPathLoadTool.Create(obj.Name)
tl = obj.Group[0]
tool = Path.Tool()
tool.Diameter = 3.0
tool.Name = str(tool.Diameter)+"mm mill"
tool.CuttingEdgeHeight = 15.0
tool.ToolType = "EndMill"
tool.Material = "HighSpeedSteel"
obj.Tooltable.addTools(tool)
tl.ToolNumber = 1
# GUI edit tool
obj.ViewObject.Proxy.deleteOnReject = True
obj.ViewObject.startEditing()
# close GUI window
What puzzles me is the editing.
I would like to know what's going on there.
Thanks for your patience, sliptonic!
sliptonic
Post by sliptonic »
Take a look in the PathScripts/PathContour.py file.
You'll see classes for the TaskPanel, the contour object itself, the viewprovider, etc. There's a class called CommandPathMillFace. This is the command that gets registered if the GUI is up. The Activated method is the code executed when the button is pushed.
# GUI edit tool
# close GUI window
[/code]
It fires a signal. It's executing the code in the ViewProviderFace.setEdit() method to close any other dialogs and open the task panel.
jcf
Post by jcf »
Thank you, sliptonic.
That seems to be the information I needed! :D
I'll have a look at it as soon as I can.
jcf
Post by jcf »
I have progressed a little bit in understanding the Path scripts.
Now I am able to create a path Job object and set my parameters:
# -*- coding: utf-8 -*-
# Macro for initializing Path Job and setting tool and feed rate
import FreeCAD
import PathScripts.PathJob as PathJob
import PathScripts.PathLoadTool as PathLoadTool
import Path
# create Path Job
myjob = FreeCAD.ActiveDocument.addObject("Path::FeatureCompoundPython", "Job")
PathJob.ObjectPathJob(myjob)
# get first drawing object and set it as job.Base:
objs = FreeCAD.ActiveDocument.Objects
firstobj = objs[0]
myjob.Base=firstobj
# Create tool
tool = Path.Tool()
tool.Diameter = 3.0
# Load tool:
PathLoadTool.CommandPathLoadTool.Create(myjob.Name)
myjob.Tooltable.addTools(tool)
tl = myjob.Group[0]
tl.ToolNumber = 1
# set feed rates
tl.HorizFeed=200
tl.VertFeed = 200
tl.HorizRapid = 300
tl.VertRapid = 500
tl.SpindleSpeed = 10000.00
myjob.X_Max= 400
myjob.Y_Max= 300
myjob.Z_Max= 50
myjob.Z_Min= -80
myjob.UsePlacements = True
# eventually activate GUI edit tool
## myjob.ViewObject.Proxy.deleteOnReject = True
## myjob.ViewObject.startEditing()
# close GUI window
# activate Path workbench:
# Gui.activateWorkbench("PathWorkbench")
The Base object is the first object in the drawing, which in my test example is a Rectangle.
Then I create a contour:
import PathScripts.PathContour
Gui.activateWorkbench("MyPathWorkbench")
# create contour object:
mycontour = FreeCAD.ActiveDocument.addObject("Path::FeaturePython", "Contour")
PathScripts.PathContour.ObjectContour(mycontour)
PathScripts.PathContour._ViewProviderContour(mycontour.ViewObject)
# set properties:
mycontour.Active = True
mycontour.ClearanceHeight = 20.0
mycontour.StepDown = 1.0
mycontour.StartDepth= 0.0
mycontour.FinalDepth= -3.0
mycontour.SafeHeight = 12.0
mycontour.OffsetExtra = 0.0
mycontour.Direction = "CW"
mycontour.UseComp = True
PathScripts.PathUtils.addToJob(mycontour)
PathScripts.PathContour.ObjectContour.setDepths(mycontour.Proxy, mycontour)
and there seems to be something missing or wrong, but I don't know what.
I get these warnings:
DeprecationWarning: For future usage 'Curve' will return 'Line' which is infinite instead of the limited 'LineSegment'.
If you need a line segment then use this:
Part.LineSegment(edge.Curve,edge.FirstParameter,edge.LastParameter)
To suppress the warning set BaseApp/Preferences/Mod/Part/General/LineOld to false
which seem to be due to my Rectangle Base object (creatzed with Face = True)
and at the end:
Something unexpected happened. Unable to generate a contour path. Check project and tool config.
I suppose that
  • either I have done something wrong / omitted something
  • or my drawing Base object is not the right type for Curve / Libarea
Can anyone give me a hint?
jcf
Post by jcf »
Actually my code seems to work! :D
I didn't notice because I forgot
FreeCAD.ActiveDocument.recompute()
at the end.
Another thing is that I updated Freecad - daily ton 0.17R10101
The Path module I use is an older one however, can't tell from when.
(I wanted to keep this as it had made me nice G code once, and as sometimes when updating, the scripts in the /Mod folder had disappeared. So I am happy to have this one)
jcf
Post by jcf »
Now I can generate a contour path by script.
The next step is to attack the profile path.
I have looked at the code which seems to be more complex, while part of this complexity lies in guessing the base object as it seems to me.
I have not fully understood which kind of object this must be. May it be 2D? For my approach the easiest would be Rectangle, Circle etc.
Or would it be better to switch to 3D? Note that my decision to start with 2D and to write my own code was that there were difficulties making a path at all, and problems with changes in FreeCAD that made me going mad as what worked yesterday did not work today. So I hoped that if I understand the code I can build something that works for me, as long as FreeCAd is still evolving.
So my question is: how can I make a contour path by code, based on objects that I selected befor or that I set by code?
