I was working on this project some months ago, it shows the parametric capabilities of FreeCAD.
Almost every parameter of the design is customable from a spreadsheet, if you want to test it, just change de "Cantidad ruedas" (number of wheels) value for a number higher than 3 (the higher the number, the longer it takes to generate the model).
It was designed with FreeCAD 0.16 and uses functions from the Part Design, Part, Draft and Spreadsheet workbenches. In this next days I'm gonna rebuild it from scratch using the new Part Design workbench (FC 0.17), making the model less susceptible to break from parameter changes.
The FreeCAD file and renders are apparently too large for the forum attachments, but everything is on my GitHub https://github.com/gsegura96/FreeCAD-Omniwheel.
Hope you like it, please let me know any problem or recommendation.
PD: for now everything is in spanish, the next revision will be translated to english.
Parametric omniwheel
- microelly2
Re: Parametric omniwheel
Thank you for sharing this.
It's a really interesting technical device
let's look how to improve computational speed
Wow Interesting
Thanks for sharing!!
What is such an wheel good for? Where would you use such an wheel? I actually have never seen such an wheel.
Hi, I've just realised I didn't add any explanation about the wheel.
This kind of mechanism is used in robotics to generate movement in any direction without mayor friction.
In this video you can see an excellent use of them.
- kkremitzki
I have used them in the past on robots to allow it to move back and forth among rows without needing to turn around. You also can see them in use on things like forklifts in warehouses for the same reason of not wanting to have to turn with the huge moment arm associated with what you're lifting.bernd wrote:What is such an wheel good for? Where would you use such an wheel? I actually have never seen such an wheel.
I think I have the file around here somewhere, I'll try to find it and see if I can polish it a bit before putting it up on the user showcase.
Edit: Here's a render for now.
- render_5.JPG (481.99 KiB) Viewed 5503 times
Thanks guys I got the point about this kind of wheel! Very cool stuff!
Those are available commercially and are normally not used as wheels, but as rollers for omnidirectional movement of goods.bernd wrote:What is such an wheel good for? Where would you use such an wheel? I actually have never seen such an wheel.
See https://www.google.de/search?q=allseite ... ource=univ for examples or http://www.euroroll.de/allseitenrollenschienen.html for one of many vendors.
Regards
Ektus.
